Y-board Buffer combo LJ92-01601A IC testing?
+ More Options
Posts
  • Glitcher
    • Mar 2013
    • 673
    • USa
    This is coming from a PN50B450
    Does anyone know how to test the buffer IC's for shorts on this Ysus/Buffer board?
    Tested all the common resistors that usually blow.
    I found the usual 6 mosfets shorted, Then found the driver IC (irs21956s) had a short. Replaced everything that but still same problem, sound but no picture.. Retested everything on the board and there are no shorts but I still have the same sound but no picture.
    I still haven't replaced the other smaller driver IC (irs21856s) but it ohmed out good. (Haven't ruled it out yet though)
    Only thing I thought left were the Buffer ICs, but how do you test these? (No obvious burnt marks)
    Re: Y-board Buffer combo LJ92-01601A IC testing?
    If you have -Vsc and Vsch the buffers are likely OK, at least they would not cause no picture. Any glow from panel? Do you have access to a scope? Check voltage across the bank of red caps on Y-main should match X-main same caps. Also check if logic board LED flashing.
    • Glitcher
      • Mar 2013
      • 673
      • USa
      I have 2 of these panels so tested by taking the y-main from the good one and putting it in this one and it fired up normally so im sure the original y-main is still bad somewhere...
      I'm not leaving the panel on for too long as im testing cause I feel like something might blow soon. There is no glow from the panel. Vsch reads -49v. I can't get a reading from Vscan, its making my meter go crazy, even on the highest setting (600v) its reading off range??
      The red caps on the y-main read 102.2V and 104v on the x-main.
      Heres what I got from the scope.
      I also noticed that the middle heat sink is hot while the left and right ones are still cool to the touch.
        Well you do appear to have Vscan as it's the lower part of the sustain waveform & your board is sustaining the panel. Can you try checking at one of the buffer outputs? It's plausible missing/shorted floating 5V could cause your issue.
        • Glitcher
          • Mar 2013
          • 673
          • USa
          I tested with the scope on this circled cap, is that buffer output?
          I found one of my old threads with the same panel and I found a photo of a working y-main for reference.
            That's a good place. What V/div scale is your "bad" scope shot taken at?
            • Glitcher
              • Mar 2013
              • 673
              • USa
              Its at 5v/div X10 probe
                So that reading is OK, weird. Since you have the other board, could you check resistance across some of the little MLCC caps around the buffer chips?
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  Heres the readings I got, its around the same for each batch near each IC.
                  The only difference I found was that the bad board had one reading of 10K while the good board was out of range for my meter. This was seen on each batch.
                    Wish I had a bright idea, that's a stumper; don't necessarily think that 10k is a bad reading, could just be a production change from one board to another, any different rev #?
                    There should a little 5V 7805 regulator for the buffer logic supply, can you see one? Note, it floats wrt to -Vsc so don't short it or test it to ground.
                    Also, could you try taking a test at the buffer output - there appear to be metal pads at two parts of the board leading off the buffer ICs, this might provide more useful info.
                    • Glitcher
                      • Mar 2013
                      • 673
                      • USa
                      The bad board is Rev AA2 and the good is AA1, the only difference I see is that AA1 has bodge job which added a resistor and the AA2 rev has the resistor actually built in.
                      I might have to come back to this set another day.
                      • cliff_hootarski
                        • Jul 2006
                        • 411
                        Check resistance across the two power resistors below the third buffer IC from the top
                        of the board. Low resistance indicates one or more bad buffer IC's.... this is from a UK
                        seller of repair kits on eBay.
                        rev. AA2 board http://www.ebay.com/itm/LJ41-05905A-...item3f31f39fa0
                        rev. AA1 board http://www.ebay.com/itm/LJ41-05905A-...item3f32c25c1c
                        • JamesTV
                          • Nov 2014
                          • 3
                          I know this is an old thread but I did want to chime in anyway. There is a SMD 3 ohm resistor to the right of the first MOS-FET that opens and a 47 kohm SMD around the corner from it next to the heat sink. The Shorted MOS-FETs will open either both of one of these but you don't get them included in any kits available for sale.
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                          • Yanleb
                            Schematic or datasheet for Plasma TV buffer chip
                            by Yanleb
                            I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                            So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                            Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                            05-18-2022, 01:36 PM
                          • legg
                            LG 42PC3 buffer output doesn't follow YSUS
                            by legg
                            LG42PC3D -UD originally with green lamp but no display or audio.
                            Owner says was working, then went 'pop'.
                            All 5V caps bulging. replaced.
                            All PSU output voltages within spec but -Vy is low on YSUS.
                            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                            eventually shorts DG. Replaced all 3 - -Vy now OK.
                            Y scan buffer test point does not follow YSUS output below -50V
                            Note: This unit seems to expect YSUS output to park at -Vy in between
                            drive signal pattern periods. A replacement drive signal board confirms this....
                            11-18-2021, 11:49 AM
                            I found this video when looking for something else but this is how to use a phone charger for testing LED light bulbs
                            by sam_sam_sam
                            Here is the website link for this project that I plan on making
                            https://www.youtube.com/watch?v=atLERDZx0Q8
                            But I going to use a different enclosure for this project and make it more professional looking and use safety features that was not used in this video
                            I have some 24 volt switching power supply from my battery testing machine that I modified for a different switching power supply that is more suited for my new application and new purpose for testing BMS protection boards
                            If can find one that I can modify the voltage output on I have a...
                            09-09-2024, 04:47 AM
                            Some New Preliminary testing of 21700 Tool battery cells to 2.00
                            by sam_sam_sam
                            I decided to try a new approach to testing unbalanced battery cells with my battery testing machine that has more graph curve information and it looks like if you discharge them to 2.00 volts if the battery voltage does not come back to over 3.something volts you have some kind of issue with that battery cell
                            I going to do more testing and see if is the case or not
                            More to come later
                            05-04-2023, 05:11 AM
