I have a lg plasma, I have fixed many lcds buy no plasmas. This tv had a blown fuse on y sus, it has 2 fuses on that board. 1 was blown, I replaced it and it turns on but no picture. On screen where y sus is, it has like fuzzy stuff on screen. But I. Figure there a component on y sus board that I can fix? What should I look for? I don't know how to check the 3 legged mosfets. So any help will be well appreciated.
i want to learn how to fix plasmas, please help
Tags: None
Re: i want to learn how to fix plasmas, please help
I think I'd post some pictures of the setup, the fault and the model to help everyone identify if it's a common fault.I have a lg plasma, I have fixed many lcds buy no plasmas. This tv had a blown fuse on y sus, it has 2 fuses on that board. 1 was blown, I replaced it and it turns on but no picture. On screen where y sus is, it has like fuzzy stuff on screen. But I. Figure there a component on y sus board that I can fix? What should I look for? I don't know how to check the 3 legged mosfets. So any help will be well appreciated. -
Check out the Application-Note in my sig.
It gives a fair idea on how a plasma screen functions. Its much better than any maker's info as it hasnt been poorly written--Then translated to English!TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
by cmlewis89Hi folks,
I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...12 Photos -
by drscootHP Modelnumber: 14-dh0061nb
This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
All these 3 batteries are charging...2 Photos -
by w00pzI have blown a component on HP Envy x360 with motherboard G1 13 AMD X360 18740-1 448.0GA03.0011.
Unfortunately there are no schematics available and the component was so blown the marking weren't readable.
I have marked it with a red circle in the attached photos - sorry for the mediocre quality I was too much in a rush.
Hope someone will be able to identify the component.
Many thanks for your help!
Edit: High-res picture added on a normal board (not mine)...2 Photos -
by swergHey everyone,
I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components... -
by ohrenI'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
R533 right below it in the photo is charred, but measures the correct value.
1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...1 Photo-
10-21-2025, 09:02 AM -
- Loading...
