Proscan 40LC45S Ghosting bad color
+ More Options
Posts
  • CraigR
    • Dec 2013
    • 959
    An odd problem with a Proscan 40LC45S. Turned it on cold this morning and picture was just great and left it go for about 45 minutes and no problems. To double check I turned the set off for about 3-4 minutes and now color is way off and there is ghosting. See this video:
    http://s231.photobucket.com/user/WAL...de9ca.mp4.html
    Not sure what to even check with this one.
    I have it off now and put in a cold place to see if that will "reset" it somehow.
    Re: Proscan 40LC45S Ghosting bad color
    Looks like a panel driving fault. I'd check the t-con board voltages: AVDD (15~17V), VONE (~20-30V), VOFFE (-5~8V)
    However, if it's intermittent, you might be looking at a panel fault.
    • CraigR
      • Dec 2013
      • 959
      Check right at the board?
        • CraigR
          • Dec 2013
          • 959
          I can not see anything marked with that. Forgive my ignorance but where to I tap in to check those voltages? here is a TCON board pic.
            On yours, I see VON_P, VON, VOFF, and AVDD test points. Little gold pads, white silkscreen next to them.
            You use your meter, red probe on point, black probe on chassis, report the voltage reading.
            • CraigR
              • Dec 2013
              • 959
              Wow do you have some good eyes! took me a while and a magnifying glass but here is what I got VON P=22.68V VON=18.53V AVDD=15.11V
                Check VOFF too, if you could.
                So far, those are all good, so I suspect the panel.
                • CraigR
                  • Dec 2013
                  • 959
                  Voff=7.45v
                  • CraigR
                    • Dec 2013
                    • 959
                    So bad TCON?
                      Voff should be negative, is it?
                      • CraigR
                        • Dec 2013
                        • 959
                        Sorry, Yes it is negative.
                          Tcon is working. Probably panel.
                          • CraigR
                            • Dec 2013
                            • 959
                            Hmmm, so a mainboard problem would never cause that either right?
                            • CraigR
                              • Dec 2013
                              • 959
                              So screen is shot then?
                                Yes, that is my opinion, if you were to try to fix it you could try a tab bond shim, but no guarantees at all if that will work.
                                • CraigR
                                  • Dec 2013
                                  • 959
                                  Took apart down to tabs and pushing or touching and moving on the tabs made no difference what so ever to the picture.
                                  • CraigR
                                    • Dec 2013
                                    • 959
                                    Well looks like one for scrap. I got a TCON board just to give it a shot and same thing so I will need to scrap this one out.
                                    • auser
                                      • Mar 2015
                                      I have one of these TVs and it began making a sizzling sound from the back side on the right side, when viewed from the front. Yesterday, Mar 9, 2015, it stopped working with no picture and no sound, except for a popping sound. It will not turn on, status light middle bottom red, and I cannot turn it on using the side power button. I took the back cover off and no obvious problem. I need to test voltages on the PS board. Are any service manuals available? Thanks.
                                      Warren, some Dyna, some Marantz, some McIntosh, some Mercedes, some Kenwood.
