LG 42PC1D Dismantling
  • raverbaby01
    • Mar 2014
    • uk
    hello...
    my ysus board has failed on my LG 42PC1D.
    i have sorced and ordered the parts online....
    I'm no expert so i was wondering if anybody knew of a guide to taking the Ysus board out....
    its nicely tucked away inside and i was a bit concerned about accidentally breaking something.
    also...can i ly the screen down at all..? or is it just myth that it can't be laid flat...
    Many thanks in advance
    Dan
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: LG 42PC1D Dismantling
    Yes--perfectly safe to lay flat on the floor/table providing nothing is placing any pressure on the glass of the screen--say a screwdriver or other small object.
    42PC1DA/DV is fairly easy to work on--Just loads of screws--like any plasma.
    You'll need to lift up the signal block, best to disconnect all the smaller plugs from PSU along bottom edge, the earth wire from the frame near mains socket and the two aux-socket plugs in the grey wiring, one each side of the signal-block tray....
    Take care of the small multi-way plugs on the Y-SUS, they are rather feeble and easily broken....
    TELEFIX
    • raverbaby01
      • Mar 2014
      • uk
      cool.. thank you.
      i will take a crack at it and see how i get on.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Out of curiosity, --How did you diagnose the Y-SUS was actually faulty?
        --The IPM modules--those large heatsink things,--are a bit of a weak-spot on the LG sets after so many years, and some guys dont like 'em because of this...
        They say, that the IPM's have a finite lifespan--then again so does most stuff these days since the RoHS Directive took lead out of electronics.
        All the dead IPM's Ive seen have had the heatsink compound dried out and turned to dust--Maybe a contributory factor.....
        Personally, I like these sets, and am in the middle of reverse-engineering the IPM's these models use.
        Ive had some success replacing the faulty parts inside the IPM, so the next stage is complete duplication, all-be-it constructed differently with discrete parts instead of the surface-mount things the IPM uses.
        Let us know how you get on....
        TELEFIX
        • raverbaby01
          • Mar 2014
          • uk
          well... i was really going with the majority over the forums....
          no picture but sound.
          blown fuse on the ysus board.
          got the board out with no problem... now just awaiting a finer tipped soldering iron to tackle taking the IPM out.
          the replacement IPM turned up today... along with fuse's and compound for heatsink... so just a matter of time i hope
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Take a look at the various tutorials on youtube on IPM removal--They are buggers to remove without damage to the finer print signal connections like the SUS-Up/Dn and ER-up/dn etc....
            Perhaps the best way--without the correct tools--(Fine pointed iron probably wont do it) is to make a tool to do the job.
            A nice chunk of solid copper--piece of bus-bar or similar with slot cut into the side heated and tinned.
            --Place this over ALL the pins down one side, allow the solder to melt on all at the same time and Carefully ease that side upwards from the board.
            --Do the same the otherside....
            Heat conduction by the multi-layers of thick copper print--as well as the heatsink and the IPM pins makes de-soldering with std. 25/40w iron virtually impossible.
            I use a 70W iron on 450 degrees (Flat out!)--VERY CAREFULLY, but this job still takes nearly an hour to do!
            Use LEADED solder to first tin up the connections Before de-soldering.
            BTW--Your 'new' IPM wont be new--It'll be S/H, with gawd-knows how many hours on it--New ones are not (never have been) available, only recovered ones.....
            Check yours VERY carefully for shorts and tiny black marks on the 'die' chips using a Jeweller's Loupe, any found--its toast.
            You can test the IPM dynamically by running a 12V 55W lamp through three of the four MOSFET 'channels' by driving the inputs and supplying 15V to the two control-chips in the IPM. The fourth needs a square-wave of 50-100KHz at 5V p/p as the driver to MOSFET is AC coupled on that one....
            TELEFIX
            • PlasMatt
              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
              by PlasMatt
              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
              09-20-2025, 06:50 PM
            • legg
              LG 42PC3 buffer output doesn't follow YSUS
              by legg
              LG42PC3D -UD originally with green lamp but no display or audio.
              Owner says was working, then went 'pop'.
              All 5V caps bulging. replaced.
              All PSU output voltages within spec but -Vy is low on YSUS.
              One of three parallel fets between SUS_OUT and SUS_DN is zenering,
              eventually shorts DG. Replaced all 3 - -Vy now OK.
              Y scan buffer test point does not follow YSUS output below -50V
              Note: This unit seems to expect YSUS output to park at -Vy in between
              drive signal pattern periods. A replacement drive signal board confirms this....
              11-18-2021, 11:49 AM
            • Truncatedhose
              Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
              by Truncatedhose
              Greetings all!
              Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
              Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
              07-04-2018, 10:59 AM
            • zwarder
              eax61319402 50PJ350 YSUS
              by zwarder
              Hi
              Had shorted YSUS
              Q24 RPJ63F3
              C726 cap
              Q11 K3667
              R528 & R529 2.2 ohm
              replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
              ZSUS is also good as far as I can tell
              Anyone could help me out on this one
              10-23-2023, 08:11 AM
            • maces
              LG 60PH6608 YSUS repair
              by maces
              Hello all,
              I have a problem with my LG 60PH6608. The TV is only clicking and doesn't get started.
              I checked the power supply and measured that the 200V is shorted at the YSUS board.
              All IGBTs, the MOSFET K8A60DA and the diode D603 are shorten.
              So I replaced the parts. I checked the further parts for shorts and I was pretty sure that there is no further problem on the board.
              So I plugged it in. Directly, resistor R251 (2,2 Ohm) blowed out with a little spark. Immediately I disconnected the TV from supply.
              I checked the replaced parts (IGBTs, MOSFET...
              12-11-2022, 02:21 AM
