Samsung Plasma hp-t5054 catasrophic failure
  • keats11
    • Nov 2012
    • 88
    Hey all,
    I have a Samsung 50 inch plasma (which is similar to several other models like the one many have contributed to on here). Basically the Ysus failed catastrophically, several shorted fets, transistors and a SMD transistor along with a blown upper Y buffer board. I have replaced all the blown fets and transistors etc on the Y main, and with just the bottom buffer plugged in the TV turn on, does the "doodilydey" and the lower half of the screen is lit. However there is no picture on the lower half. I read somehere that this set doesnt fire up without the upper buffer.. is this true? So why does my lower half of the screen light up? Please tell me of your experience with this model, I am trying to figure out if my Ysus is Ok before plunking down money for a new buffer board.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung Plasma hp-t5054 catasrophic failure
    With this era of Samsung plasma TVs the Y sustain board must transmit the data to the upper buffer and if that signal is achieved then y sustain board will transmit the data to the lower. it is what it is and if you are getting a glow from the lower half of the screen then the Y sustain board is working but you will not have a picture until you replace the upper buffer board.
    • keats11
      • Nov 2012
      • 88
      Ok freakaftr8, thanks a lot for that confirmation. Since the buffer board for this TV is expensive, I have decided to hand solder the buffer IC's. Just ordered the IC's, sharpened my soldering tip (which was a chisel shape, now a pointed one) using the bench grinder and ordered a wearable pair of magnifying glasses like that of a watch repairer. Eagerly waiting for the IC's to arrive. Will keep posted.
      • mmartell
        • Oct 2013
        • 3189
        I did mine with a chisel tip. Much better for heat transfer and you don't have a problem if you use lots of flux
        • Mxracer3651
          • May 2014
          new to the forum and have the same issue. no picture , replaced mosfets and Ic's still nothing.
          • Mxracer3651
            • May 2014
            did you have success.. I have the same problem right now and need some help
            • capkid
              • Oct 2010
              • 1339
              Which mosfets did you replace? Also, did you check nearby resistors and diodes?
              LG Plasma Mal-Discharge Correction Service
                09-07-2024, 05:50 AM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
                Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 06:20 PM
