firmware Samsung PN50A4501DXZA
  • electrojas
    • Nov 2013
    • 40
    • usa
    Can anyone point me to a place I can get latest firmware for Samsung PN50A4501DXZA?
  • electrojas
    • Nov 2013
    • 40
    • usa
    Re: firmware Samsung PN50A4501DXZA
    Anyone at all? I cant find any firmware or the actual service manual for this. Im needin yall right now on this.
      Samsung might not have released any updates for this TV, the only firmware would be the original.
      • RON_CET
        • Jun 2012
        • 217
        Try this attached
        Note!!!! This is for the PN50A450P1DXZA Did you leave out the (P) in your model???
        Ron Driver,BSEE,CET,ISCET,NESDA
        • RON_CET
          • Jun 2012
          • 217
          attaching part of service manual
          • electrojas
            • Nov 2013
            • 40
            • usa
            Hey thanks a lot friend I really appreciate your help on that. I did find an updat for the firmware on Sammy's site it was 1013, yours is 1018. I am going to look at that for sure. I flashed it without incident yesterday from 1008 to 1013 but the 1013 was still from 2008 which is the manufacture date. It did ad a lot of functionality in the menu that wasnt there before. Yes it is PN50A450P1DXZA. I left the P out thanks for pointing that out. May I as you where that firmware you gave me came from originally being it didnt show up on sammy's site? Thanks again friend for your help. It means alot to me.
              09-07-2024, 05:50 AM
            • GeckoGreen
              Samsung service bulletin: need firmware file for PN63C550 TV
              by GeckoGreen
              I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
              You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
              The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
              Will you please help me get the [2D63]LOGIC.bin file for my TV?
              05-17-2025, 02:47 PM
            • sikocan
              NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
              by sikocan
              I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
              However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
              01-11-2024, 01:47 AM
            • Mirenia
              Samsung UEMU6199U - no Standby - bad Firmware?
              by Mirenia
              I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
              Voltages on the power supply board is okay. Backlight test is also okay.
              I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
              So I think my TV has exactly this issue.
              Can someone please fix the dump?
              And how do you do that?
              As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
              05-12-2025, 06:13 AM
              09-06-2024, 11:40 PM
