usp440m-42lp psu
  • joehezzer
    replied
    Re: usp440m-42lp psu
    Originally posted by paulstef
    Oops, that's not good. I didn't analyze that part of the circuit because mine is working. I'll have a look at it.
    Where exactly you say you had 5V?
    its dead all over i found somewhere that the big blue relay could be at fault
  • joehezzer
    replied
    Do you have a voltage at the output of the bridge rectifier BD101? It's the two outer pins.
    Very minimal voltage botton pin 01.6 upper pin 01.4 v
  • paulstef
    replied
  • paulstef
    replied
  • joehezzer
    replied
    Originally posted by wills123
    i think its basically the same mine is branded as a tevion but alot scrrens seem to share those same innards
    i see
  • joehezzer
    replied
    D103 reads 01.2 vdc 01.3 vac i am gonna pull diodes and test them and see if they are shot
  • wills123
    replied
    Originally posted by joehezzer
    ok just had a look at shopjimmy and that is the substitute part have you the same 42" plasma screen !!!!
  • joehezzer
    replied
    give me 5
  • paulstef
    replied
    Ok,
    1. measure from cathode of D103 to the long heatsink (that's primary ground) . When plugged in you should have immediately 170VDC (for 120VAC input). What's the voltage?
    2.
    If you can't measure 5Vsb on CN801 but you can measure Vctrl on CN805 I could check how they are linked.
    Before turning on the unit through 5Vsb - RLY-ON - VS-ON the only power supply that works is the one with the NCP1203. If you have voltage on the ZD501 and ZD502 this chip works. What's the voltage over these two zener diodes?
    An oscilloscope would help.
    EDIT: I think the voltage in UK is 230VAC? In this case you should have about 325VDC from cathode of D103 to heatsink
  • joehezzer
    replied
    In post #14 you said you have 5VCtrl. You should also have 5Vsb.
    What comes out of the PFC?
    If you have 5Vsb you could try to disconnect everything and drive RLY-ON directly from Vsb via a resistor maybe.
    i was looking for the standby point to measure i could only see the 5v control point, i had no voltage from anything
  • paulstef
    replied
  • joehezzer
    replied
    Joe,
    could you do me a favor and measure the voltage over ZD501 and ZD502?
    I'm having the same problem but at least VA and all low voltages are working now after I swapped some caps.
    See my thread here:https://www.badcaps.net/forum/showthread.php?t=36026
    hi paul yes will give it a go bud, but the problem i have i have no voltage anywhere, i do not even have a standby light nothing, i am wondering if something on the hot side of the board is dead, hence no power any where else, i will check for u though just incase
  • paulstef
    replied
    Joe,
  • joehezzer
    replied
    its not exactly the same but i found it was an equivilant for the one i had, i think it was shopjimmy listed is an equiviliant, you would have to double your part number against it
  • wills123
    replied
  • joehezzer
    replied
    i recently just did one of theese, managed to get a psu from ebay for £30 delievered, the one i had , b/r shorted and a load of mosfets ,so got another board
    http://www.ebay.co.uk/itm/4004140660...84.m1497.l2649
    it wasnt really worth doing but my missus likes the tv an for keeping her quiet............... priceless
    Is that the same psu
  • wills123
    replied
  • joehezzer
    replied
    a bigger picture, the numbers on the pics refer to the first pic then the second and so on, but i think i kinda screwed it up lol
  • joehezzer
    replied
    ok so i have measured all the 5v standby and a couple of others and i am still getting no readings at all, they are all marked in yellow
  • joehezzer
    replied
    Originally posted by Alastair E
    OK--Thats one of the 5V lines--there's usually a few. Some will be powered, some not when in standby.
    Check 'em all, post results and the names/references of 'em pref with a pic of the plug you measured them at...
    ok will do tomorrow cheers matey
  • dicky96
    Need to buy buck regulator MP2329CGG but struggling to find supplier
    by dicky96
    Hi guys
    I need one of these MP2329CGG for a repair job. It's a 24V 6.5A buck converter. But I have not been able to find a supplier who has that component.
    Actually I would buy a few as I always think if I found one faulty already I will probably find more in the future
    I had one supplier on Aliexpress who gave me a price $2 each, but I have been waiting some days since I asked for shipping price and they don't reply
    Does anyone know where I can buy that part in small quantity (let's say 5 of them), or any equivalent I could use? it supplies the Standby...
    03-05-2021, 08:44 AM
  • Faileng
    Struggling with a soldering job, need help.
    by Faileng
    Hello, although I've never been formally taught soldering techniques, etc... I've not really run into too much trouble soldering, with the exception of this job...
    I've got a supposed blown transistor on my fuel pump on my car and I'm trying to replace it. It's a gel encased circuit booard with very fine connections. Please see photo uploaded.
    I've cleaned up the area that I'm working on with alcohol scraped off the wires, etc..
    I cannot get any solder to now stick any of the connections, I've used various grades of solder and flux combination, nothing...
    02-06-2020, 02:07 PM
  • Dreigas
    Laptop, Bios and some phones schematic database
    by Dreigas
    About a year ago, I was struggling to find schematics whenever I needed them. As a programmer, I saw an opportunity and wrote a few scripts to automatically gather a large database of them. Today, I've decided to share it with everyone, because good things should be accessible to all.
    What's included? Over 14,000 laptop schematics, as well as some BIOS files, and about 1,000 phone schematics.
    Everything is compressed in a RAR format and is over 140 GB. (Since it's such a large file, your browser might show a warning.)
    I plan to host the...
    08-20-2025, 09:58 AM
  • mburke26219
    Pc Specialist GM7TGxP Bios and EC Problem
    by mburke26219
    Hi All,
    Currently struggling with this bios and EC Problem and hope someone with more knowledge might be able to help, so my laptop PC Specialist Ionico 17 ( Tongfang GM7TGxP / 11800h rtx 3070 ) had lower than normal resistance on the PCH, so before i changed the pch i attempted to flash a bios/ec from same type of laptop board ( i am not the original owner and PC Specialist would not help ) which did flash ok but no change, after that i changed the chip and all resistance readings from all rails were normal, so i turned the laptop on with the new PCH and it turned on as soon as i...
    08-03-2025, 05:30 AM
  • Techie_hobby1
    Help identifying a component please
    by Techie_hobby1
    Struggling to identify this component.
    I thought it might be an Linear Regulator but the pins in the circuit don’t seem to correspond
    Many thanks
    07-30-2025, 07:37 AM
