Need BIOS dump for ASROCK FM2A55M-VG3
  • rockman97
    • Aug 2025
    • 10
    • Hungary
    Hello guys,
    I am struggling to find bios BIN file for ASROCK FM2A55M-VG3 (i had the normal VG3 not the VG3+)
    When i download from official website, and put that in EZP2019+ programmer software it says ''FILE LENGHT, BEYOND RANGE OR IT WILL BE IGNORED''
    That means that file i downloaded is larger than chip says, even tho chip is 8mb and file is 8mb.
    It has the Winbond 25Q64FVAIQ chip what i need to select the prgoram?
    I created a backup but when i rewrite its not work.
  • m1ch43lzm
    • Mar 2019
    • 769
    • Peru
    You have to cut first 0x1000 bytes from the BIOS on ASRock website, here it is ready to flash
    • rockman97
      • Aug 2025
      • 10
      • Hungary
      Thank you sir now the BIOS chip is got detected correctly i erased and reflashed and verified sucessfully but when i install back my motherboard the chip i got black screen and no beep.
      I did a CMOS reset aswell i changed memory and CPU but nothing.
      I tried the components another mainboard works like charm.
      Thank you really for help hope i can fix the issue.
      • rockman97
        • Aug 2025
        • 10
        • Hungary
        Thank you so mutch! <3 Finally i able to post but sadly i found one of my dram slot are not recognize memory modules. It was a really old motherboard from 2015 i had issues like this before.
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • khanhtq0
          Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
          by khanhtq0
          I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
          I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
          I suspect the original Intel ME and descriptor...
          08-06-2025, 02:14 AM
        • bondminer009
          Need Bios for Latitude 7650 (No Original / dump bios file)
          by bondminer009
          Good Evening,
          Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
          Thank You
          Salam,
          Three
          11-12-2024, 07:48 AM
        • joshAU
          BIOS file for N550JK (original dump attached)
          by joshAU
          Hi all.
          I'm looking for a BIOS file for an Asus N550JK.
          I have a Asus R552J, which I believe is identical to the Asus N550JK.
          I downloaded the latest BIOS (210) for the R552.
          It is named N550JKAS.210.
          The BIOS file is however only 6mb in size.
          I've read the chip with a CH341A programmer and verified the file.
          That file is actually 8mb in size.
          I'm wanting to remove the BIOS password from this unit.
          It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
          08-09-2022, 08:06 PM
        • adelage
          Merge ECS Z77-H2 bios cap file with original dump
          by adelage
          I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
          03-11-2025, 03:07 AM
