Samsung UN65JU6500FXZA ID03
This topic has been answered.
  • Crux85
    • Aug 2024
    • 8
    Hello Badcaps!
    I've got a older Samsung TV that has been on the fritz for awhile, but finally stopped working altogether a few days ago. For a few months, it has randomly turned itself off after being turned on for about 15 minutes, the power light on the front would blink, and would turn itself back on after a few minutes and seem to work fine for the rest of the day/evening. The problem had slowly been getting worse until it has gotten to the point it won't power on at all. Disconnecting, letting it set for a few hours, and reconnecting the power doesn't change the behavior. It has always been connected to a surge protector, and nothing seemed excessively dusty/dirty.
    I removed the back panel to see if there were any obvious signs of problems. No capacitors look bulged or popped. All connectors looked good. There are some heat marks on the power board, not scorched, but certainly noticeable.
    Any guidance or troubleshooting advice would be greatly appreciated. Thanks!
  • Answer selected by Crux85 at 08-05-2024, 01:00 PM.
    R_J
    • 9624
    Remove the power supply board and resolder all connections on the main transformer (TM801CS) and all components attached to the heatsinks like QM801CS and Q802CS, Also LP801CS & 802CS
    Caps that can be weak are CM824, CM825 & CM826
      • 12331
      • U.S.
      With tv unplugged from power, unhook cable from powerboard to mainboard on powerboard side, with it unhooked plug power cord into powerboard, see if backlights come on and stay on.
      • R_J
        • 9624
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4542
          • Italy - Milan
          First thing to do is to test the PS board itself with dummy loads, if ok then probably bad solder under the CPU, needs reballing..
          • Crux85
            • Aug 2024
            • 8
            I think this may be right on point. I missed a very gnarly looking solder on this component that could easily be shorting out. I'll resolder this evening and let you know the results.
            • lotas
              • Jan 2016
              • 4883
              • Russia
              Not here, but on the back side of the board... (circular cracks on massive components).
                • 12331
                • U.S.
                Examples of bad solder joints: https://www.google.com/search?client...h=541&dpr=1.09
                • Crux85
                  • Aug 2024
                  • 8
                  The solder joints on the main transformer was the problem. Not sure if it was just a faulty solder or if something developed over time, but the joints were still solid. I just cleaned up the problem joint with a quick filing and I've had no issues the last few days.
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
                    Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                    This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 06:20 PM
