2020 LG 75UM8070PUA 4K problem
  • bscottjohnston
    • Aug 2023
    • 52
    Opinion time - anyone ever fix one of these? I just fluxed and reflowed the BGA along with some thermal epoxy on the heatsink for the logic/motherboard and the issue is still the same (refer to video attached). Anyone think this is worth the gamble buying the complete board kit from SJ? $125 gets me a PSU, Tcon and Main/Logic. "Mouse" control works on screen until the crash. Would you gamble?
    https://www.shopjimmy.com/lg-75um807...air-parts-kit/
  • nomoresonys
    • 12305
    • U.S.
    Video didn't work for me, can you just explain what it's doing, do you want to do some troubleshooting? As for is it worth the kit, it's a big lg direct lit tv so I'd say it's worth it, most lg tvs from the last 10 years at least have usually had very good picture quality imo. You probably want to make sure it isn't something like bad led/s in the backlights at least before buying the kit.
    • bscottjohnston
      • Aug 2023
      • 52
      Backlights work perfectly. They never go out. "Mouse" function works on screen before the screen goes blank. Thinking maybe its Tcon but I haven't fixed a TV in a few years outside of board swaps.
      https://youtu.be/keY2528ysn4
      • nomoresonys
        • 12305
        • U.S.
        Could be, maybe try a tcon first, they are usually pretty reasonably priced. Might be some on ebay.
        • badboyzzz
          A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
          by badboyzzz
          I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
          12-28-2024, 02:11 PM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • sdogs
          Macbook Air 2020 A2179 820-01958 battery problem?
          by sdogs
          I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port intermittently).
          After a first inspection I could see that the D3302 protection IC was burnt out, so I replaced it but the problem was not solved, it seems like intermittent 5v input.
          I then replaced the two u3200s (CD3217B12ACE) and now I have stable 20 volts and the macbook has turned back on.
          Unfortunately I have a further problem, it works very slowly and the fan runs at maximum and if I disconnect the charger it turns off, it's as if the battery was disconnected.
          02-08-2024, 08:00 AM
        • Guest
          A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
          by Guest
          Hello all!
          Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
          After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
          09-26-2024, 03:31 AM
          Huawei MateBook 14 2020 Netbook 14 Specification for Upgrade or Repair
          This specification for the Huawei MateBook 14 2020 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 2020 boardview and 14 2020 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Huawei...
          09-06-2024, 10:20 PM
