ledn42k15p not turn on
+ More Options
Posts
  • topng
    • Dec 2013
    • 56
    • ISRAEL
    hi my led tv do not turn on i have blue led but it dont start
    i buy new psu and still no power up .
    the switch not Respondsץ
    any help .
    psu : rsag7.820.2264
    display : rsag7.820.4207 ver.a
    Re: ledn42k15p not turn on
    Can you supply pictures of the circuit boards in the TV?
    • topng
      • Dec 2013
      • 56
      • ISRAEL
      i will take a pic later
      but here is the psu schamtic
      http://www.520101.com/html/hisense/21541513.html
      the main board is the problem
      I found some capacitors short
      • topng
        • Dec 2013
        • 56
        • ISRAEL
        here is the main
        here is the psu
          Have you checked you are getting the right supply voltages from the power supply?
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            you may need to check for ripple on the power supply capacitors though,because they may be sending a little to much AC through wrecking the main board caps,not known them to fail much.infact i havent found one lol
            fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
            please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              You've never had a bad main board? I've had several and done 1/10th the TVs you have. Must be odd luck.
              • topng
                • Dec 2013
                • 56
                • ISRAEL
                hi tom and multimeter
                i find that {mst6e48rhs-lf-sj} is making shortes
                whan i take it off from the board
                i saw no short in the circuit
                did it a Programmable chip or can be replaceable one on one ?
                  It looks like it has external flash chip, so you do not need to reprogram it. It will run code from the flash chip instead.
                  Beware though, it's rare for a CPU to fail. So you have to ask why? it could be because of a bad voltage regulator or excessive supply voltage. I had one board fail and put 5V onto the 3.3V standby of micro, after that, it came back dead short, only got really hot.
                  • topng
                    • Dec 2013
                    • 56
                    • ISRAEL
                    hi Tom thanks for the help
                    in my opinion 'when burned satellite receiver it took the TV with him
                    it was connected via hdmi .
                      That could easily do it, looks to be not much protection for HDMI.
                      • topng
                        • Dec 2013
                        • 56
                        • ISRAEL
                        ן removed all voltage regulators from the circuit and checked them
                        With external power supply
                        • topng
                          • Dec 2013
                          • 56
                          • ISRAEL
                          i will look for where I can buy this and update
                          if you know a shop that can quickly send'd love to hear
                            I found one guy but minimum order 30 ICs. Maybe you can negotiate for just one.
                            http://www.aliexpress.com/item/4-new...037153637.html
                            • multimeter
                              • Jan 2011
                              • 739
                              • united kingdom
                              i mean the smd caps on a mainboard,yes had plenty of mainboards gone bad!,hate working on them,lots have been EEPROM faults ,especially the vestals with the plug in EEPROMS ,yuck!
                              • topng
                                • Dec 2013
                                • 56
                                • ISRAEL
                                hi tom & multimeter
                                replaceing the chip {mst6e48rhs-lf-sj} solved the problem..
                                • tribble
                                  • Apr 2015
                                  • Israel
                                  hi guys havin the exact same problem. thought about consulting with you before replacing the chip (which I can't locate on the Board btw). could this be caused be something else?
                                    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-06-2024, 05:30 AM
                                  • ajc333
                                    Dell Precision 7710 - it can not be turn on and off with the switch
                                    by ajc333
                                    Hello.
                                    Markings on the board AAPB0 LA-C551P REV:4.0 (A03). The laptop came to the service with the fault of shutting down after a few minutes of load such as a game. It turned out that the smaller fan was damaged, a complete original cooling system from dell was ordered and from this time everything is back to normal. The problem, however, is the inability to turn on and off the laptop with the switch. On the switch board, the voltage drops from 3V to 0V when the switch is pressed.
                                    On the connector on the board (from the right side) I have the following voltages:
                                    n1. - 3V after...
                                    03-10-2023, 07:27 AM
                                  • Egidio85
                                    Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                    by Egidio85
                                    Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                    the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                    the fan does not start.
                                    I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                    any advice on what to check?
                                    06-10-2025, 05:00 AM
                                  • dionzarek
                                    PS5 Slim EDM-040 Only turn on 1 Sec, Blue light then immediate off.
                                    by dionzarek
                                    Hello everyone, I am new to this PS5 troubleshooting, I need help on diagnosing the problem. My PS5 Slim board EDM-040 that beep and only shows blue light then immediately turn off.
                                    I've checked the PSU its normal 12V. I've checked all the capacitors its all good no shorts, but there are 2 caps shorted, I think its near the SSD. You can look at the image attachment.
                                    When tested it only shows 0.003 while other caps show 0.4 to 1. WHen in continuity mode those 2 caps goes beep/shorted.
                                    Any help to where should I check on or suggestion would be very appreciated....
                                    02-08-2025, 11:00 PM
                                  • Natob82
                                    Micro Momentary Push Switch?
                                    by Natob82
                                    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                    12-21-2022, 05:22 AM
