panasonic TX-P42S20E plasma tv difficult to turn on
  • anno
    • Sep 2007
    • 140
    • netherlands
    hi
    i have a panasonic plasma tv. model tx-p42S20E. it is hard to turn on, eventually it is turning on. sometimes first try , sometimes 20 tries.
    the power led is flickering green , then it goes to red again. 1 sec on , 3 seconds off. i have service manual and it says it's an unknown fault.
    i tried to disconnect the power cables to the x and Y board but same symptom.
    can anybody help me? thanks
  • anno
    • Sep 2007
    • 140
    • netherlands
    Re: panasonic TX-P42S20E plasma tv difficult to turn on
    i measure voltage on big 450v cap and voltage is low 270v
      Does 450V cap voltage hit 390V when it does turn on? What does it do as it fails to power up? What do Vs and Vda measure when this occurs?
      • tw2005
        • Oct 2011
        • 6458
        Sounding like SOS1 - A board replacement
        Can't tell you much more, being intermittent hard to know whether it's the processor or something simple like a bad cap on the board.
        I have had SOS1 due to bad flash chip but that was permanent 1 blink.
        Generally you'll need an A board. Not too many A board repairs seen for this but it's something that would be nice to nail in case it was something simple.
        Could try warming the board and see if it turns on easier but not that will prove a lot.
        • anno
          • Sep 2007
          • 140
          • netherlands
          it doesn`t want to start atm. the vsus voltage is 205v and the vda is 60v.
          maybe here is a PFC problem because the low voltage on the big cap?
          • tw2005
            • Oct 2011
            • 6458
            I don't see how with those voltages which are normal.
            • anno
              • Sep 2007
              • 140
              • netherlands
              ok. is it possible to test the power supply standalone?
              with resistors on some 'on'' pins ?
              can i take a 230v lightbulb for the vsus load?
              i am not sure wich pins i have connect with each other
              P& connector is labeled :
              1. STBY5V
              2. GND
              3. S0
              4. S1
              5. F_STBY_ON
              6. ECO-ON
              7. Panel_main_on
              8. STBY5v_on
              9. SOS4_PS
              10. AC_low
              11. ALL_off
              12. main_Sw_1
              13 NC
              14. Main_sw_2
              • anno
                • Sep 2007
                • 140
                • netherlands
                i think i didn`t measure the voltage right. because i couldn`t reach the big cap i measured on the + - legs of the rectifier. but PFC is further down the line, if you know what i mean. So its probably error of the A-board? I checked pin 5 en 7 of connector 7. When starting up they are 3,3 volt both and when turning of they go to 0 volts. (F_stby_on and panel_main_on) . Is this because A-board is turning of the main power supply?
                is it possible a voltage regulator on the mainboard is not working? i work on tv tommorow again
                • tw2005
                  • Oct 2011
                  • 6458
                  NO. Not in my opinion. Do you have any manuals or guides? problems with sub voltages etc all have their own error blinks.
                  SOS1 - Panel information SOS, PD5 Start SOS
                  Search PD5 in the service manual PDF doc and you'll end up in the A board.
                  • anno
                    • Sep 2007
                    • 140
                    • netherlands
                    yes i have service manual.i have 1 sec blink 3 sec no blink . Error 1
                    it says unknown SOS . panel information SOS PD4 start SOS
                    i don't know what panel information SOS and PD4 start SOS means. But i think i'm going to find and replace the A board. thanks for help
                    • tw2005
                      • Oct 2011
                      • 6458
                      Sorry , looked at the S30, but same,same. PD4, panel SOS. I cleared a X20 which had SOS1 confirmed corrupted flash ic, but yours being intermittent hard to say.
                      Not a board many try to fix with the 1 blink, new A board should sort it if you can get one. make sure you get the correct revision as i suspect with that the same PCB may be used for both HD and FHD models and different sizes as well.
                      • anno
                        • Sep 2007
                        • 140
                        • netherlands
                        I changed the A-board and the tv is fine now. thanks
                        • KORHAN DEGIRMEN
                          • May 2014
                          • 10
                          • TURKEY
                          Dear Anno;
                          How could you find A BOARD for TX-P42S20E? Could you please share with me?
                          I have some problem with A board too.
                          https://www.badcaps.net/forum/showthr...581#post444581
                          • anno
                            • Sep 2007
                            • 140
                            • netherlands
                            sorry for the late reply, but i found in a webshop that sells used lcd/plasma parts
                            http://www.lcd-onderdelen.nl/a-37205...s/tnph0838-1a/
                            i am not sure thats the good one. someone told me to reflow bga chip on A board. i have not tried that
                            • jm1234
                              Panasonic plasma TX-P42ST50 - 6 blinks
                              by jm1234
                              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                              I checked that board for any obvious faults...
                              05-22-2024, 06:59 AM
                            • novak2
                              Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                              by novak2
                              Hello there,
                              I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                              The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                              From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                              Thanks in advance.
                              09-25-2020, 02:34 PM
                            • cloo
                              Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                              by cloo
                              I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                              It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                              So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                              After doing a factory reset this problem was gone and the picture was back to...
                              01-06-2025, 06:02 AM
                            • Alicat
                              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                              by Alicat
                              Stopped by this site trying to fix my parents Panasonic Plasma TV.
                              Model number is TH-50PZ85U
                              Power comes on and the red power light stays on solid.
                              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                              I also hear a few clicks.
                              I also think my parents said there was a thunderstorm and the TV failed after that.
                              Section 6 in the service manual talks about power and no screen,...
                              10-30-2024, 10:09 AM
                            • Lintesir
                              Panasonic P42S30 Plasma - Pink sparkles
                              by Lintesir
                              My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                              There is about a 5cm high region at the top without any sparkles,...
                              07-26-2024, 03:16 AM
