OLED65CX5LB PSU Feedback Loop Issues
+ More Options
Posts
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4281
    • Italy - Milan
    the photo i see around are almost low quality but i surely see no signs of variable voltages in different modes in serigraph
    • CiorapulUcigas
      • Jul 2024
      • 16
      Replaced TL431 and no fix.
      • CiorapulUcigas
        • Jul 2024
        • 16
        I think I found the solution here. I have ordered parts and will find out in the coming days.
        • CiorapulUcigas
          • Jul 2024
          • 16
          I guess we have our guilty parts.
          • CiorapulUcigas
            • Jul 2024
            • 16
            Changing those caps fixed it, but the relay doesn’t turn off when the tv turns off.
            • thommyX
              • Apr 2016
              • 93
              Which brand did you use?​
              • Diah
                • Feb 2013
                • 6354
                if the 12VM go back to 8.5V after you turn off the TV... then every things in good. dont bother.. but if VM remain high 12V.. not good
                • CiorapulUcigas
                  • Jul 2024
                  • 16
                  #28
                  I have used wurth. The relay turns off most of the time now, but when the tv is off I hear reset clicks on the motherboard.
                  • Diah
                    • Feb 2013
                    • 6354
                    MB will never make click
                    • thommyX
                      • Apr 2016
                      • 93
                      Always check all parts for the power supply. The capacitors usually have loss.​ LG Thomas
                      • CiorapulUcigas
                        • Jul 2024
                        • 16
                        #31
                        Thank you for this, will have to check all of these out as C601 and C602 were so bad.
                        The power supply seems to be functioning good so far. I think the relay doesn’t turn off some of the times as the panel is doing pixel refresh. After 5-10 minutes I can hear it click off.
                        • B0r1s
                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                          by B0r1s
                          PSU - BN44-00878A
                          Symptoms:
                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                          A weak clicking sound was coming from the transformer.
                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                          Progress:
                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                          01-17-2023, 04:58 PM
                        • blaster_
                          Samsung UE49MU6105K - boot loop, horizontal lines
                          by blaster_
                          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                          06-22-2022, 05:19 PM
                        • Stefano Crivellari
                          Lenovo Legion 5 (15ITH6H) kind of boot loop but not sure
                          by Stefano Crivellari
                          Hi, I wonder if anyone can help me fix my Lenovo Legion 5 (15ITH6H) laptop. Basically, after a windows update the computer would not boot anymore. When powering on the laptop the screen has no backlight and nothing would show up, using an external monitor did not help. However, the laptop would still spin up the fans and turn on the keyboard backlight. The keyboard backlight intensity function key would work and the power button led and the charging led are also working. I've tried every possible combination of key press and power button hold down time but did not change anything. At this point...
                          01-14-2025, 03:49 PM
                        • Takeatry
                          Yet another Samsung QLED Boot Loop
                          by Takeatry
                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                          10-04-2024, 02:57 PM
                        • ferah831208
                          HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
                          by ferah831208
                          I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
                          12-07-2024, 04:02 PM
