Philips 37PFL5522D Blink code?
  • anotherdude
    • Feb 2013
    • 488
    Picked this set up yesterday, it powers on after unplugging at the wall and plugging back in on a few occasions but most of the time it doesn't come on and the led blinks away
    After the blue turn on led it proceeds to turn red and blinks like this
    1 blink-off and wait-6 blink-off and wait 2 blink-off
    and it continues to do this until the tv may eventually turn on
    Have looked at caps, no obvious faults, startup caps at fault?
    Once it's been on for 10-15 minutes I can turn it off and on as much as I like and it works like normal
    Re: Philips 37PFL5522D Blink code?
    Get the chassis code from the back for example LC5.9E-LA which will be useful in locating service manual. Philips TVs do use blink codes plus they also log them in the service menu so you might be able to see what the cause of it shutting off is.
    • anotherdude
      • Feb 2013
      • 488
      LC7.2E-LA
      so if i can get the tv back on access the service menu?
      ok got into the SAM menu
      error code appears
      6 2 13 0 0
      from the service manual, 6 being the last error,
      6: I2C error while communicating with the NVM
      2: 12v missing or low
      13: DVB HW Communication error
      12v, appeared to be fine when the set wouldn't power on
      trouble is once i've powered it on , it takes some time to replicate the symptomns again, i've cleared the error code in the mean time anyway to see what error i next get
        I'd focus on that 12v .... A good chance it's the cause of the other errors. Check connectors and cold joints. Maybe it's dropping out just before it powers on? Could also be a detection error.
        • anotherdude
          • Feb 2013
          • 488
          Originally posted by tom66
          I'd focus on that 12v .... A good chance it's the cause of the other errors. Check connectors and come joints. Maybe it's dropping out just before it powers on? Could also be a detection error.
          ok
          psu or main?
          seems caps would be a no as they all appear to be rubycon
          can't get it to replicate the problem again just yet
          but took readings anyway 12v is at 11.90v in standby and when on it rises to 12.30v
          • anotherdude
            • Feb 2013
            • 488
            seems you are correct tom
            12v is not there when the fault occurs
            • anotherdude
              • Feb 2013
              • 488
              ok after clearing the error code and getting the tv to power back on
              the error code is 2, +12v Protection error - low or missing 12v
              • anotherdude
                • Feb 2013
                • 488
                i've been reading into other 2 blink protection mode errors and some have solved it by replacing a resistor
                I can't find much from the service manual about tracing down the 12v fault
                any suggestions?
                  I'd try checking other rails, things like 5V main and 24V, aree they also missing?
                  • anotherdude
                    • Feb 2013
                    • 488
                    i can't see any markings for a 24v the 5v appears to be there on both connectors
                    pictures of the boards if you can point them out to me unless i'm being blind
                    • anotherdude
                      • Feb 2013
                      • 488
                      I removed the power board yesterday and never noticed this
                      On close inspection i can see a broken component it was still half hanging on the board but come off after i touched it
                      both are leading the 12v pins, this the problem i presume?
                      edit: I noticed a few times i'd hear a pop from the speakers when trying to power on it wasn't all the time but did happen and looking at the SCH now it appears those 12v lines are part of the audio
                      I just can't make out the part numbers from the SCH would anyone be able to help, i've attatched the portion of the diagram
                      • anotherdude
                        • Feb 2013
                        • 488
                        still have this, anyone any input on where to go with this
                          That's a ceramic cap, is it shorted?
                          • anotherdude
                            • Feb 2013
                            • 488
                            the whole cap was actually just hanging on so to speak and when i touched it it just fell off
                            don't have the set out atm as was put away for a rainy day
                              It could have caused your problem. My guess would be 100n ceramic. Value not critical, it is for high frequency noise suppression.
                              • cloo
                                Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                by cloo
                                I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                After doing a factory reset this problem was gone and the picture was back to...
                                01-06-2025, 06:02 AM
                              • Curtissimo
                                HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                                by Curtissimo
                                Hi everyone.
                                I have a HP Elitebook 850 G8.
                                Serial: 5CG2324XM0
                                ProdID 6L8D5EC#ABA
                                It has a Winbond W25Q256JVEN Chip.
                                I need to remove BIOS Password.
                                I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                                Attached my dump.
                                I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                                I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                                What I did:...
                                08-26-2025, 04:42 AM
                                LCD LED TV Service Menu Codes
                                ALL LCD LED TV SERVICE MENU CODES
                                Service Menu Code with Board Name
                                China Universal Board / Jumper Board Service Menu Code
                                Changhong Ruba Service Menu Code
                                Ecostar LED TV Service Menu Code
                                Orient LED TV Service Menu Code
                                Haier LED TV Service Menu Code
                                TCL LED TV Service Menu Code
                                Samsung LED TV Service Menu Code
                                LG LED TV Service Menu Code
                                Videocon LED TV Service Menu Code
                                Supra LED TV Service Menu Code
                                Toshiba LED TV Service Menu Code
                                Symphony LED TV Service Menu Code
                                Veste/ LED TV Service Menu Code...
                                10-31-2024, 03:58 AM
                              • eurgenca
                                Philips TV 43pus7505 setting display option code, help please.
                                by eurgenca
                                Hello.
                                I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
                                So I ordered a used CPU board, and now I have wired picture.
                                I think the problem lies in display option code. According to SM, the command for setting
                                display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
                                But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
                                or can I manually edit option code in SAM.​
                                10-07-2024, 02:09 AM
                              • rmacintosh
                                Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                                by rmacintosh
                                I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                                The symptoms of the tv ar as follows:
                                • Plug AC in to back of TV
                                • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                                • The 3 blink code is given by the power LED
                                • If the TV is unplugged and then
                                03-14-2020, 12:24 AM
