Samsung PS-42D4S Fault
  • ACsellers
    • Dec 2013
    • 22
    • England
    Hi I have a Samsung PS-42D4S and the screen comes on for 1-2 seconds then turns itself off then turns itself back on and repeats it. Does anyone know any problems?
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung PS-42D4S Fault
    Not many hits on here that is a good sign but not very helpful.
    https://www.badcaps.net/forum/showth...light=PS-42D4S
    Have you read Tom66s plasma problem guide - it is a sticky at the front of the forum
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
      09-07-2024, 05:50 AM
    • Egidio85
      Samsung UE55F8000SZ Turns on and off immediately
      by Egidio85
      good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
      This defect happens continuously, hearing the classic click of the relay every time.
      Power supply board BN44-00636B
      disconnecting the mains and lamps from the power board always causes the same problem.
      Is it normal that without anything connected this power supply turns on and off cyclically?
      any suggestions on what to check?
      thanks in advance
      03-11-2025, 12:45 PM
      09-06-2024, 11:40 PM
