LG Plasma TV will not turn on - Need Help
  • Meiko
    • Jan 2014
    • 7
    • US
    Hello all. I'm in need of some help.
    I have a LG Plasma TV 50PC3DH that will not turn on. It died while watching a show when it blinked with a white screen two or three times before turning off. Now when I try to turn on the TV, it clicks like its trying but then, after about 3 seconds, it turns back off. No picture or light is shown while it's trying to turn on.
    I opened the TV and noticed some bulging capacitors on the power board, so I sent the power board to get repaired. When I reinstalled the power board, the symptoms didn't change.
    Next, I checked the resistance between the Vs and ground on the YSUS and the ZSUS boards and found a short on the ZSUS. I replaced the ZSUS board with a refurbished board. Still, the TV will not turn on.
    I checked all the voltages on the connectors, and they all seem to be correct. I don't know what to check next or how to find the problem component. If anyone can please give me some advice on how to determine what the problem is, I would greatly appreciate it.
    Attached is a visual of the tv circuitry.
  • tds-1541
    • Jan 2014
    • 15
    Re: LG Plasma TV will not turn on - Need Help
    This unit appears use the same chassis as a plasma that I was just able to repair: https://www.badcaps.net/forum/showthread.php?t=34861. Long story short, I had to replace a MOSFET on the power supply board as well as an defective Z-sustain board.
    The manual entitled " lg_50pc1dr_troubleshooting_manual.pdf" was VERY helpful. I would recommend that you download a copy of that. That PDF outlines resistance values for each board and their major components. You should quickly be able to determine which board/boards are bad by measuring the resistances and comparing them to the values in that PDF. Good luck!
    • Meiko
      • Jan 2014
      • 7
      • US
      Sorry for the slow reply, I had to go out of town.
      After going through the trouble shooting guide mentioned above, I checked what I could make sense of, but I did not come up with anything definitive. While checking all the voltages against what is printed on the ysus board again, I measured 5.8 volts on the +5VF pin on the connector from the ysus to the y driver board. All the other pins on the ysus board calling for 5 volts measure 4.9 volts. Does this show a faulty ysus board or is the 5.8 volts an acceptable reading?
      Also, how do I check to see if the y driver boards are ok?
      I'd really appreciate more help!
      • PlasMatt
        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
        by PlasMatt
        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
        09-20-2025, 06:50 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • brzostos
        HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
        by brzostos
        Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
        After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
        Original HP 150W power supply, the diode in the power socket lights...
        10-01-2024, 01:34 AM
      • Cooperr
        Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
        by Cooperr
        I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
        The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
        10-21-2025, 01:11 PM
