Lg 50pc3d Clicking noice from IC201
  • dcapper
    • Dec 2013
    • 496
    I have a flickering washed out picture on the tv and IC201 (STK type of chip) of the YSUS board is clicking. I checked Vs=196v, Va=60v. The panel says -vy should be -200 and it is. VSC should be 120 and it is. I metered all the pins on IC201 and IC202 and there is no shorts anywhere. Since my voltages are correct could it be that chip? I pulled the ZSUS and IC5 and IC7 are not shorted. When the ZSUS is plugged in, I get the proper incoming voltages and the ZBias is at 93v like the panel says it should be. Now I'm wondering if its the YSUS or ZSUS. I know the power supply is working fine.
    Re: Lg 50pc3d Clicking noice from IC201
    It is probably a Y-sustain fault. There are two IPMs on these sustains, an ER one and a SUS one. If the ER one goes, you can get clicking or flickering screen, if the SUS fails you typically get a shorted PSU or blown fuse.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Pull the Z-SUS Vs supply fuse, re-try.
      If you have a very dark and odd patchy coloured--but stable picture, Z-SUS ER IPM is most likely faulty, and the heatsink will be stone-cold. IPM type--YPPD-J015 or16C/E probably.
      Check the voltage across the ER caps, (the row of dark red film caps on the 'sus' boards)--should be 90-130V (with fuse back in) on both the Y-SUS and Z-SUS.
      IF you have dual-channel scope, monitor both Y-SUS and Z-SUS, the Z-SUS should be a square-wave, leading rising edge lining up with middle of Y-SUS-between the ramps.
      --If it looks a bit like the Y-SUS wave, but flat-topped, Z-SUS IPM ER IGBTS are likely stuffed--New IPM or board needed.
      Unfortunately--They dont always fail shorted, Some fail Open-Circuit, so no shorts will be found during testing.
      --These sets run those IPM's pretty hard and hot--still they last average 15-20K hours--but no brand-new are available--only S/H, advise fit a quiet fan to direct air over the pair on each board when you're done.
      TELEFIX
      • dcapper
        • Dec 2013
        • 496
        Thanks! I have no scope but I'll meter those points tonight after work. I did pull the power plug on the ZSUS last night but the tv would turn on then off. Looks like all the boards are daisy changed. Power Supply to YSUS to ZSUS to Main Board. If I need a new SPI-50X3E120, is it safe to get them out of China? $10 out of China. $50 out of North America.
        • dcapper
          • Dec 2013
          • 496
          I tried to meter the brown caps. They are too close to the board to get a lead in, and nowhere to follow it. The ZSUS doesn't have a glass fuse to remove. There is 2 glass fuses on the YSUS though. How do I know which chip is which? Is IC201 my ER or SUS. 201 is the top one closest to where the power comes in from the mainboard. It's also the one that is clicking.
          • dcapper
            • Dec 2013
            • 496
            Does anyone know what the part numbers would be for IC201 and IC202 on the YSUS? The service manual I have doesn't have them listed.
            • tw2005
              • Oct 2011
              • 6458
              Is there not a white label along the side of the module itself?
              • tw2005
                • Oct 2011
                • 6458
                YPPD-J015(A,B,C) , YPPD-J016(A,B,C) ? Apparently you need to match the revisions of these.
                http://blog.coppelltvrepair.com/2010...on-screen.html
                http://www.coppelltvrepair.com/p/99/...ard-repair-kit
                • dcapper
                  • Dec 2013
                  • 496
                  Thank you. I guess I'll have to pull them both to get the numbers and letters. I'm thinking the top one (IC201) is bad since its the one clicking.
                  I read what Coppells said "1) TV flashing white screen about every second and a ticking sound can be heard (if you have good ears) from the YSUS board;" but they don't say which module it is.
                  • tw2005
                    • Oct 2011
                    • 6458
                    don't know enough about them but replacing the pair is probably a good idea. Horrible job and i'm biased to the point that I don't think these are worth the time effort or money for the quality of picture they produce at least that's what i saw with the 50PX5D.
                    Good luck with it anyway, it'll be an experience for you. I'll never forget mine.
                    • dcapper
                      • Dec 2013
                      • 496
                      Thanks. The chips to replace are $90 but I can buy a used board on Ebay for around $100. Probably the better route. I just want to put the tv at the lake. Got the tv for almost nothing so it would be worth it in the long run. Did you get your working again?
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        IF you are adventurous, and keeping the set for your own use--You could try replacing the IGBT's in the IPM....
                        This involves cutting out the 'die' devices and adding std. package parts to the heatsink, running wires then into the IPM module....
                        --I think there are 4 IGBT's in the J015/6 IPM's
                        I did this on the 42PC1D I have, --which is still going....
                        I have a 50" at work that I plan on doing the same to, This time--I'll take some pictures of whats done, I didn't bother with the 42, as it was more of an experiment that I was pretty sure wouldn't work...
                        TELEFIX
                        • tw2005
                          • Oct 2011
                          • 6458
                          Yeah, I did 3 the same model, all needed IPMs. I had one where a bad ysus was smoking 2 SMD resistors on the Z. Got better at doing the modules but very agricultural. Had to track repair the first one, too much heat. Tried heatguns but the PCB started to delaminate before the solder even melted.
                          Ended up using a 80W iron and long strips of solder wick flooded with solder to heat enough pins to slowly get it out bit by bit.
                          I sold mine so for the effort not much made on them but satisfying to get them going.
                          Of course if you got it for nothing that helps make it a little more worthwhile.
                          • dcapper
                            • Dec 2013
                            • 496
                            I replaced the Y-SUS today and this is the picture I'm getting. Of course I am getting sound. Both heatsinks on both sustain boards are getting warm. TV turns off after 20 seconds. But when I unplug the ZSUS power the tv stays on. I'm getting proper voltages out of the power supply into the YSUS and out of the YSUS to the ZSUS too. Any ideas on this?
                              Looks like you might also have a bad buffer board, but it is repairable. There are some surface mount FETs on them which can sometimes fail.
                              • dcapper
                                • Dec 2013
                                • 496
                                Hi Tom,
                                Are the buffer boards beside the YSUS? In the service manual they call them drivers. I replaced the top ydrv. There is a bdrv, xrlt, xrct, and xrrt. Are those the boards I'm looking at? You are always so helpful.
                                EDIT: Also when I unlpug the bottom boards from the YSUS the tv still stays on.
                                  Yeah the buffers are also known as the YDRV boards.
                                  • dcapper
                                    • Dec 2013
                                    • 496
                                    Wow, I need to read more. I kept reading thinking it was the ZSUS. I pulled the bottom driver and its the top of the top is working.
                                    I just metered Q101, Q102, and Q103 on the blown board and they are all shorted.
                                    Also D111, D112, D113 are too.
                                    EDIT:
                                    Pulled up the pins on Q103. All the shorts went away except for Q103. Going to replace it and see what happens.
                                    Replaced Q103, still not working. I'm assuming IC104 is toast. Don't feel like replacing it, since I can buy a used board on ebay for $20.
                                    • dcapper
                                      • Dec 2013
                                      • 496
                                      Lower buffer board should be here this week. I'll update my findings.
                                      • veikra
                                        • Sep 2012
                                        • 55
                                        • canada
                                        I have a 50pc3d-ue with a clicking ic201 and im unable to find a IPM to buy. shop jimmy and ebay
                                        4921QP1047A-H is on the heatsink label.
                                        Anyone knows where to get those now?
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • mikelu53
                                          Samsung UN60D8000YF Clicking BN44-0432A
                                          by mikelu53
                                          I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
                                          The set was working then not,then started clicking.
                                          Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
                                          Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
                                          A schematic or suggestion would be great.
                                          01-21-2023, 03:14 PM
