Problem with Samsung Tv UE49MU6120KXZT (Version 01)
  • RGSound
    • May 2024
    • 12
    • Italy
    Good morning I have a problem with my Samsung UE49MU6120KXZT (Version 01) TV with Motherboard BN94-12644A.
    After disconnection from 220V the TV remains switched off with status led off. I need information on how to proceed with reprogramming the flash memory and the BIN file to reprogram it.
    I have purchased this programmer on Ebay: CH341A EEPROM PROGRAMMER FLASH BIOS 24 25 SERIES + CLIP TEST. I include photos of the motherboard. I am not very experienced but I would like to learn so the more detailed the information, the better it will be for me to proceed with this repair.
    If there is already a thread of this type can you send it to me or link it, thanks in advance
  • lotas
    • Jan 2016
    • 4602
    • Russia
    Look for a chip on the motherboard with number IC1604 (spi flash 25Q40CL), unsolder it and, through the adapter on the programmer, read the data (dump) from it and post it here, I will fix it and you will write it back to your chip and solder it in place...
    • RGSound
      • May 2024
      • 12
      • Italy
      Thank you very much, I will proceed as you told me, one more question which programme should I use to run the programmer? with the purchase they didn't provide me with anything, only the programmer.
      • Storyteller12
        • Jun 2020
        • 624
        You will most likely have to mod that programmer to be able to set the registers. There are a few threads that mention how to do it and google also.
        • lotas
          • Jan 2016
          • 4602
          • Russia
          "NeoProgrammer V2.2.0.10" is best suited.
          • RGSound
            • May 2024
            • 12
            • Italy
            hello Lotas, here attached the dump from the chip (i've changed the ext from .bin to .txt)
            • lotas
              • Jan 2016
              • 4602
              • Russia
              Why, pack it in zip or winrar.
              • RGSound
                • May 2024
                • 12
                • Italy
                I attach winzip
                Thank you​
                • lotas
                  • Jan 2016
                  • 4602
                  • Russia
                  Try.
                  • RGSound
                    • May 2024
                    • 12
                    • Italy
                    I tried but it won't turn on
                    • lotas
                      • Jan 2016
                      • 4602
                      • Russia
                      And status register (0x88, 0x42) was set and written after recording dump?
                      https://www.badcaps.net/forum/troubl...ung-ue49mu6120
                      In this thread I explained to everyone many times how this is done...
                      • RGSound
                        • May 2024
                        • 12
                        • Italy
                        All OK up to point 7, as you can see from the attached photo I have no S7, S3, S14 and S9 to put a check mark on.
                        "In the program:
                        1. Click "Detect Chip" and select W25Q40CL and "Select IC".
                        2. Click "Unprotect".
                        3. Click "Erase IC" and "Yes".
                        4. Click "Open File" and select your corrected Dump.
                        5. Press "Program IC" and "Yes".
                        6. Click "Verify IC".
                        7. Press the down arrow to the right of "Unprotect" and select "Edition SREG", put a check mark on S7, S3, S14, S9 and press "Write" and "Yes"
                        7. Close the program. Ready."​
                        • lotas
                          • Jan 2016
                          • 4602
                          • Russia
                          Status register: 1
                          S7 (SRP0)
                          S3 (BP1)
                          Status register: 2
                          S14 (CMP)
                          S9 (QE)
                          • RGSound
                            • May 2024
                            • 12
                            • Italy
                            Thank you very much for your help and support, by following the instructions the TV finally works!
                            • lotas
                              • Jan 2016
                              • 4602
                              • Russia
                              Congratulations!
                                09-07-2024, 05:50 AM
                              • howardc64
                                Samsung UN55JU650DF network/streaming problem
                                by howardc64
                                Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                07-09-2025, 12:44 PM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
