Vestel tv, how to flip the image?
  • France_53
    • May 2024
    • 6
    • Italy
    Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing the Telefunken because it is older and because the "XD" TV has new LED bars and T2 tuner... thank you very much​
  • yokoono
    • Apr 2010
    • 481
    Save the panel profile from the TV and post it here to return the image.
    1. Format a stick with FAT32
    2. Create a folder called downloadpq.mb110 on the stick
    3. Turn on the TV and type MENU 4725
    4. Go to USB Options and type OK on the remote control
    5. After 10 seconds you can remove the USB stick and you will have some files on the stick.
    6. You post them here.
    • France_53
      • May 2024
      • 6
      • Italy
      Hi yokoono, I have done the operation and am attaching the zip file with the contents of the TV ... if I did well​ 😀
      • yokoono
        • Apr 2010
        • 481
        It's ok.
        2. Create a folder called pq on the stick
        3. Unzip and put the 2 files in the folder
        4. Turn on the TV, USB stick and type MENU 4725
        5. Go to USB Operations and type OK on the remote control
        6. Wait 10 seconds and exit the menu (return, back)
        7. Turn off the TV from the remote control
        8. Wait until the stby LED on the TV stops flashing
        9. Unplug the TV and wait until the stby light goes out.
        10. Take out the stick and turn on the TV.
        If the image is not correct, repeat the operation
        L.E. The motherboard in the TV used the VES315WNDS-2D-N12 panel​
        • France_53
          • May 2024
          • 6
          • Italy
          Hi, it works perfectly, thanks! Are you basically giving the mirror control via USB? Well done! 😉
          exactly, that was the original panel, but unfortunately it broke after changing the bars, and I took the other panel from the Telefunken TV
          • yokoono
            • Apr 2010
            • 481
            The TV starts with the Telefunken logo ???.​
            • France_53
              • May 2024
              • 6
              • Italy
              Ah no no, it starts with the "XD" logo as with its original panel
              • yokoono
                • Apr 2010
                • 481
                OK.
                • yokoono
                  • Apr 2010
                  • 481
                  I forgot that you changed the panel, not the motherboard.​
                  • France_53
                    • May 2024
                    • 6
                    • Italy
                    oh, yes haha, well in that case yes, Telefunken would come out on this type of TV, I think
                    • DanL15
                      • Nov 2024
                      • 7
                      • Ireland
                      Hi, I currently have the same problem after fitting a donor screen. Perfect picture but upside down?
                      32” Walker tv with faulty screen ves315wnda-2D-N12 and I’ve replaced it with a donor screen VES315WNDA-2D-N22 from a 32” Bush. Both Vestel.
                      I’ve tried the method you have listed above but it’s not working? I maybe doing something wrong?
                      In post #4 you say to ‘put the 2 files in the folder’
                      Which 2 files?
                      When I recover information from the original screen I have 15 files on the USB stick.
                      • yokoono
                        • Apr 2010
                        • 481
                        Main is 17MB110 ??
                        Panel is VES315WNDA-2D-N22 ??
                        6. You post them here.​
                        • DanL15
                          • Nov 2024
                          • 7
                          • Ireland
                          Here are the files, hope they are correct.
                          • yokoono
                            • Apr 2010
                            • 481
                            Panel profile. Inverted image​
                            • DanL15
                              • Nov 2024
                              • 7
                              • Ireland
                              Success but using a different method.
                              I followed to above instructions but after i pressed 'ok' on USB Operations i got a 'please wait' message on the screen but then after 3-4 seconds it reverted to the service menu screen with the picture still upside down.
                              What i then did was the regular update procedure.
                              Unplug TV and insert the USB
                              Hold 'OK' while plugging the tv in.
                              wait till standby light stops flashing
                              Unplug tv and wait for Standby light to go out
                              remove USB and plug tv in
                              power on.
                              Picture came on correct way and now working perfect.
                              Many thanks for the files yokoono!
                              • DanL15
                                • Nov 2024
                                • 7
                                • Ireland
                                A few hours on test and everything is going fine.
                                Digital Tuner, Scart, HDMI etc are all ok but the Sat Tuner has disappeared from source inputs?
                                This may have happened when I originally uploaded a version of software for the MB110P to see if it would correct the picture problem?? It’s not even showing in Service menu either?
                                Anyway, the picture is the correct way up now 🙂
                                • yokoono
                                  • Apr 2010
                                  • 481
                                  2. Create a folder called downloaprofile.mb110 on the stick
                                  • DanL15
                                    • Nov 2024
                                    • 7
                                    • Ireland
                                    Here are the files
                                    • yokoono
                                      • Apr 2010
                                      • 481
                                      Profiles
                                      2. Create a folder called profile on the stick
                                      3. Unzip and put the 3 files in the folder
                                      • DanL15
                                        • Nov 2024
                                        • 7
                                        • Ireland
                                        Hi, I’ve tried that a few times but it’s not working?
                                        still no satellite tuner showing in source.
                                        Happy to get picture sorted anyway, Satellite tuner was not being used anyway.
                                        Thanks you so much 👍🏻
                                          MSI Summit E13 Flip Evo E13 FLIP EVO A11MT-018AU Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the MSI Summit E13 Flip Evo E13 FLIP EVO A11MT-018AU Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E13 FLIP EVO A11MT-018AU boardview and E13 FLIP EVO A11MT-018AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 04:10 AM
                                          MSI Summit E16 FLIP A13VET-027BE Hybrid (2-in-1) E16 Flip Specification for Upgrade or Repair
                                          This specification for the MSI Summit E16 FLIP A13VET-027BE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E16 FLIP A13VET-027BE boardview and E16 FLIP A13VET-027BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:38 AM
                                          MSI Summit E16 FLIP EVO A13MT-262BE Notebook E16 Flip Evo Specification for Upgrade or Repair
                                          This specification for the MSI Summit E16 FLIP EVO A13MT-262BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E16 FLIP EVO A13MT-262BE boardview and E16 FLIP EVO A13MT-262BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          MSI Summit E16 FLIP A13VFT-020BE Hybrid (2-in-1) E16 Flip Specification for Upgrade or Repair
                                          This specification for the MSI Summit E16 FLIP A13VFT-020BE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E16 FLIP A13VFT-020BE boardview and E16 FLIP A13VFT-020BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          MSI Summit E13 FLIP EVO A11MT-216FR Hybrid (2-in-1) E13 Flip Evo Specification for Upgrade or Repair
                                          This specification for the MSI Summit E13 FLIP EVO A11MT-216FR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E13 FLIP EVO A11MT-216FR boardview and E13 FLIP EVO A11MT-216FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-07-2024, 04:30 AM
