Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing the Telefunken because it is older and because the "XD" TV has new LED bars and T2 tuner... thank you very much
Vestel tv, how to flip the image?
Save the panel profile from the TV and post it here to return the image.
1. Format a stick with FAT32
2. Create a folder called downloadpq.mb110 on the stick
3. Turn on the TV and type MENU 4725
4. Go to USB Options and type OK on the remote control
5. After 10 seconds you can remove the USB stick and you will have some files on the stick.
6. You post them here.
It's ok.
2. Create a folder called pq on the stick
3. Unzip and put the 2 files in the folder
4. Turn on the TV, USB stick and type MENU 4725
5. Go to USB Operations and type OK on the remote control
6. Wait 10 seconds and exit the menu (return, back)
7. Turn off the TV from the remote control
8. Wait until the stby LED on the TV stops flashing
9. Unplug the TV and wait until the stby light goes out.
10. Take out the stick and turn on the TV.
If the image is not correct, repeat the operation
L.E. The motherboard in the TV used the VES315WNDS-2D-N12 panelAttached FilesLast edited by yokoono; 05-12-2024, 09:31 PM.
Hi, I currently have the same problem after fitting a donor screen. Perfect picture but upside down?
32” Walker tv with faulty screen ves315wnda-2D-N12 and I've replaced it with a donor screen VES315WNDA-2D-N22 from a 32” Bush. Both Vestel.
I've tried the method you have listed above but it's not working? I maybe doing something wrong?
In post #4 you say to ‘put the 2 files in the folder'
Which 2 files?
When I recover information from the original screen I have 15 files on the USB stick.
Main is 17MB110 ??
Panel is VES315WNDA-2D-N22 ??
If the image is not correct, repeat the operationAttached FilesLast edited by yokoono; 11-04-2024, 09:01 AM.
Success but using a different method.
I followed to above instructions but after i pressed 'ok' on USB Operations i got a 'please wait' message on the screen but then after 3-4 seconds it reverted to the service menu screen with the picture still upside down.
What i then did was the regular update procedure.
Unplug TV and insert the USB
Hold 'OK' while plugging the tv in.
wait till standby light stops flashing
Unplug tv and wait for Standby light to go out
remove USB and plug tv in
power on.
Picture came on correct way and now working perfect.
Many thanks for the files yokoono!
A few hours on test and everything is going fine.
Digital Tuner, Scart, HDMI etc are all ok but the Sat Tuner has disappeared from source inputs?
This may have happened when I originally uploaded a version of software for the MB110P to see if it would correct the picture problem?? It's not even showing in Service menu either?
Anyway, the picture is the correct way up now 🙂
2. Create a folder called downloaprofile.mb110 on the stick
Profiles
2. Create a folder called profile on the stick
3. Unzip and put the 3 files in the folder
