samsung UE43MU6105KXXC
  • Willail
    • Jan 2016
    • 29
    • France
    Hello, i have a TV Samsung UE43MU6105KXXC.
    The TV doesn't turn on and no standby light. The problem started after a power failure
    Could someone please check the file i dumped from 25Q40CL?
    Willail
  • lotas
    • Jan 2016
    • 4753
    • Russia
    Try
    • Willail
      • Jan 2016
      • 29
      • France
      Thank you Lotas. I will test it by using Neoprogrammer.
      Could you please give me some advices? When i push the button write to fix the status registers nothing happens.
      Is this normal?
      With Asprogrammer, it was impossible to tick the box QE when i fix the status registers
      • lotas
        • Jan 2016
        • 4753
        • Russia
        What was supposed to happen? I'm just tired of explaining to everyone how to correctly record a dump on this chassis ("MU series")
        1. First you need to delete all status registers (uncheck all the boxes and click "Write")
        2. Erase the chip.
        3. Write down the corrected dump and check what was written down.
        4. Set the status register (0x88, 0x42), check the boxes and click "Write"
        5. Everything is ready, solder the chip in place.
        • Willail
          • Jan 2016
          • 29
          • France
          Thank a lot for this useful advice.
          I didn't know that i need to delete all status registers before erase the chip.
          I will test this and give you the result
          • Willail
            • Jan 2016
            • 29
            • France
            Hello Lotas,
            I follow your advice for the writing of the chip and the tv starts.
            I use Neoprogrammer. It is impossible to tick QE with ASprogrammer 21013 fix
            You are the best.
            Thanks a lot Lotas
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
              09-07-2024, 05:50 AM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
