Samsung UE55RU8000 reboot and then double image after heating up
  • Cornito
    • Jan 2024
    • 93
    • France
    Hello team,
    I'm back with another tv and another problem.
    I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
    First, reboot issue, I use tape Method to find out the right side that cases the issue.
    Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
    Then double image reduce in height and move to the top.
    The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
    When I restart the tv the problem desapears during few second then come back.
    When tv ia off for hours I can use it correctly during close to one hour.
    It seems to me that a component is heating up causing the issue.
    Do you have an idea?
    Thank you in advance.
  • Cornito
    • Jan 2024
    • 93
    • France
    It starts with the large double image then stop with the 2-3 black lines and picture like folded in the area.
    Some pictures to show more
    • Diah
      • Feb 2013
      • 6503
      RU RU RU. series .... how could you ask a lame man to run marathon ??
      • Cornito
        • Jan 2024
        • 93
        • France
        Ahah it's not a TU 😉
        bit I guess that most of the Samsung are really bad
        • Diah
          • Feb 2013
          • 6503
          R, M. N. T UHD are a lame man.lol
          • Cornito
            • Jan 2024
            • 93
            • France
            Lol; Ok, but it's the first time I face to this kind of issue and only after some times running.
            What can explain this behaviour while the TV is heating up.
            It seems that relative to Clock signals, as the defect if changing and moving, it seems to me that it's not the panel itself, maybe on driver bords or µC on the T-con which is integrated on MB.
            Strange things
              09-07-2024, 05:50 AM
            • howardc64
              TCL 49S405 double image
              by howardc64
              LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
              This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
              06-23-2025, 03:20 PM
            • shlomim412
              samsung ua55es6800 - no image
              by shlomim412
              hi
              having problem with samsung ua55es6800
              tv had backlight on, sound working - responds to the remote control but no image.
              check tcon board - had 12v in but no other voltages present.
              when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
              when leaving only left side connected - again no voltages and no image.
              put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
              kept trying to block less pins on the left ribbon cable...
              05-15-2024, 05:00 AM
            • brkie
              Samsung UE75TU6905 reboot loop
              by brkie
              I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
              I read on Samsung's website (reviews)...
              09-04-2024, 01:45 AM
              09-06-2024, 11:40 PM
