Samsung FPT5084 50" Plasma - Randomly shuts off
  • PlasmaRon
    • Nov 2013
    • 40
    Working on the Samsung and can't really see any bad caps on the main power supply so I'm looking elsewhere for issues. I even pulled out one of the 2200uf 10v caps to test it and it was fine.
    When it clicks off, it does the red-light dance and needs to be unplugged from the AC and plugged back in.
    Any clues or experience with this model
  • Sevenqi
    • Jul 2011
    • 292
    Re: Samsung FPT5084 50" Plasma - Randomly shuts off
    Please take a look at the power supply board for the cold solder joints.
    • PlasmaRon
      • Nov 2013
      • 40
      Yes, I figured that would be the next thing to do. Without a microscope I'm not sure how I would examine all the surface mount components on the back. My plan is to use the heat gun on the boards and see if I can get it to switch off quicker. Currently it takes a couple hours before it shuts itself off.
        The cold joints in question are usually very visible; they are cracks around the MOSFETs soldered to the board and bolted to the heatsink.
        • PlasmaRon
          • Nov 2013
          • 40
          Looked for cold solder joints but nothing like that on the PS.. I tried the heat gun but nothing definitive at all. I found that if I unplug the Y and Z boards I can still get sound so I'm taking those one at a time to see if the thing powers off with each of those boards unplugged in turn.
          • PlasmaRon
            • Nov 2013
            • 40
            I found the problem! There's a thermal sensor attached to the end of the heat sink on the main power supply and it was causing the power supply to shut down because the heat sink was too hot. I removed the top of the heat sink and reapplied thermal compound and tightened up the screens holding it in place and now it runs great. I used the heat gun moving slowly around the set 'till I found the spot that was sensitive and then narrowed in on it from there.
            • mmartell
              • Oct 2013
              • 3189
              Nice catch.
              • Sony_crack
                • Dec 2020
                • 5
                I have the shutdown after start and the alarm on the power board says TH_DET....if I put a fan on the thermistor it'll keep running. Replacing the thermal compound didn't help me, but I believe I have a similar or same problem.
                • Sony_crack
                  • Dec 2020
                  • 5
                  Capacitor CQ810 ( 50V 47uF ) had high ESR ~18ohms. Once i replaced the capacitor the power board would click, but no startup. Found no 15V output from UQ802 ( 15V regulator ). Replaced the 15V regulator and the tv is back working. Heat cycled it for 2 days, no more shutdowns.
                    09-07-2024, 05:50 AM
                  • berriferous
                    Samsung PN43E450A1FXZA (Plasma) - Display up for 4 mins, then shuts itself down
                    by berriferous
                    Set was manufactured in 2012. I'm trying to diagnose where the problem is. I am assuming it is over-currenting after heating up? Display looks fine until it decides to shutdown. If I keep turning it on, it will eventually refuse to power up and requires unplugging to get it to respond again.
                    I originally thought there would be some easily detected bad electrolytic capacitors, but I don't see the telltale signs. There might be some very minimal bulging on one of the x buffer board. BN96-22092A (LJ92-01852A).
                    If I unplug the power feed to the X/Y board (LJ92-01854B), the...
                    12-16-2024, 09:58 AM
                  • Soldiaz
                    SAMSUNG LE37B650 T2PXZG shuts off randomly after wait possible to turn on again
                    by Soldiaz
                    Dear folks I am facing this issue and hope anyone can assist.
                    TV shuts off in use, Black screen,no sound, no Power LED.
                    After unplug and wait Power LED lights up again and I can use it until it shuts off again, showing no LED, no Sound Black screen.
                    I attached psu Board pic hoping someone can assist, thanks in advance.
                    P.s. 1st thought Was about the powerboard since no power led......
                    07-24-2022, 06:06 AM
                    09-06-2024, 11:40 PM
