Sony Trinitron KV32FV27 Power Supply Problem
  • cmonkey
    • Apr 2023
    • 58
    • Unitied States
    I'm just creating this thread to document this issue so I don't forget what I've tested so far.
    Technical Manual.
    I've measure CN641 on the power supply board ( board G ) and all the voltages are about half of what they should be. So the 9V pins are measuring about 5V, the 135V pins are measuring about 70V.
    I replaced the two large main caps ( C606 and C607 ) and also C643 and C641 with new capacitors without doing any more troubleshooting and strangely the TV worked for about 30 minutes and then started behaving the same way.
    I can't figure out if it's an AC or a DC side issue ( I don't know how to test the transformers and don't know their output values), so I just started measuring the voltage points in the schematic that have values. I started with IC601 since that is on the AC side and I can get 120V all the way up to it but then it gets weird. Maybe my multimeter can't measure the voltages coming off it?
    I also tested the transistor's diodes (still in circuit) and got some strange results. On the bottom of the board the pins are labeled B1, C1, E1 and B2, C2 and E2 so these must be each diodes base, collector and emitter.
    I get voltage drops as follows -
    B1 -> C1 = 0.459
    B1 -> E1 = 0..529
    B2 -> C2 = 0.459
    B2 -> E2 = 0.529​
    Those are as expected, but then I measure across the two diodes and also got a voltage drop.
    B2 -> C1 = .0529
    I'm not sure if this is normal or not. I also get continuity between E2 and C1 so there is a low enough resistance between them to register as a short.
    C1, E2 and B2 are also the pins I get weird voltage readings on as well. Maybe I need to test it out of circuit?
    Here is a photo of the schematic.
  • cmonkey
    • Apr 2023
    • 58
    • Unitied States
    Preface for today - this TV is acting very strangely, whatever fault it has on the power supply isn't constant. About 1 in 10 times I turn this thing on, it's got good voltage coming off the power board and everything works for a few minutes. Then the voltage starts slowly dropping and the picture starts warping until I turn it off. Then it's back at about half the right voltage.
    Technical Manual.
    So this isn't entirely accurate. The 5V standby voltage is good (pin 10 on CN641) and the power on voltage (pin 11) is also good at about 3.6V.
    I also think the short between E2 and C1 might be ok because they are connected via FB604 which is a ferrite bead and all the other FB components are also measuring the same. I would need to remove IC601 from circuit to properly test it I think.
    I've also tested the 3 bridge rectifiers in circuit with just a diode test and they are all measuring good. (D602, D641 and D643)
    So for now I have ordered a proper good LCR meter so I can test all the capacitors. My DMM isn't working on capacitance anymore.
    Until then I need to figure out how to properly test voltages on the HOT side of this board. I realized I wasn't measuring the pins coming off IC601 properly because I thought it was AC current but it looks like these are DC because they are after the bridge rectifier. Am I wrong here?
    What do I use for a ground when testing DC on the hot side of a power supply? Specifically I'm trying to test the pins on IC601 to see if the voltages are the same as in the schematic.
    • Donny2derby
      • Apr 2023
      • 228
      • Uk
      Diodes don’t have bases, collectors and emitters. They have Annodes and Cathodes. Transistors have Base, collector and emitter terminals.
      If you want some proper help it’s best you post up some pictures of all the boards.
      • Diah
        • Feb 2013
        • 6425
        in General over all HOT area on PSU the - GND will be references to the main filter CAP -, Cold area will be TV chassis
        • cmonkey
          • Apr 2023
          • 58
          • Unitied States
          So the transistor is tested in diode mode, but doesn't have internal diodes? I'll try to post a photo later.
          • Donny2derby
            • Apr 2023
            • 228
            • Uk
            A transistor acts as a switch, a diode is there to allow current to only pass in one direction.
            A transistor is 3 terminal, diode has 2.
            There is a diode in a transistor so that’s why they can be tested in Diode mode using a multimeter.
            • cmonkey
              • Apr 2023
              • 58
              • Unitied States
              There is a diode in a transistor so that's why they can be tested in Diode mode using a multimeter.
              Ok that's kinda what I thought.
              Here's a photo. The AC input is on the upper left. The transistor I'm looking to test voltages on is bottom right. The main bridge rectifier is middle leftish.
              Am I wrong is noticing that it looks like the AC is the striped section and DC is non-striped?
              Click image for larger version  Name:	zn2klY0.jpg Views:	0 Size:	1.79 MB ID:	3245746
              • Donny2derby
                • Apr 2023
                • 228
                • Uk
                I’m not experienced enough to be able to distinguish if it’s only AC on the striped and DC non striped but you will only have AC before the bridge rectifier and DC after that.
                • cmonkey
                  • Apr 2023
                  • 58
                  • Unitied States
                  I got around to re-capping the entire power supply board and am still having the same issue. When cold the TV turns on and runs flawlessly for about 15 minutes and then the voltages all start dropping coming off the power supply board.
                  I just replaced all the electrolytic caps. Not sure where to go from here so I'm just going to start testing various components.
                  It seems whatever has failed has not completely gone, it's just on it's way out.
                  • cmonkey
                    • Apr 2023
                    • 58
                    • Unitied States
                    Forgot to mention, one of the electrolytics did test out of range. C660 tested at 2200 nF but it should have been within 20% of 3300 nF. Regardless that didn't fix the issue.
                    Gonna test all the non-electrolytic caps next. I'm not sure what other component could work fine for 15 minutes and then fail, other than a capacitor.
                    • Diah
                      • Feb 2013
                      • 6425
                      II replaced the two large main caps ( C606 and C607 ) and also C643 and C641 with new capacitors without doing any more troubleshooting and strangely the TV worked for about 30 minutes and then started behaving the same way.
                      you have cutting / broken at print chart on boards or lost connection one legs of component at the part self.
                      • cmonkey
                        • Apr 2023
                        • 58
                        • Unitied States
                        Sorry, what do you mean 'print chart'?
                        • Diah
                          • Feb 2013
                          • 6425
                          on boards down side soldering green lines between parts
                          • cmonkey
                            • Apr 2023
                            • 58
                            • Unitied States
                            Ok, yea I've looked around for broken traces and cold joints and haven't found anything.
                            Instead of testing the other caps, I've been getting voltage readings instead and I think I'm narrowing it down a bit, specifically it's a problem on the hot side.
                            All of the voltages on the pins IC601 are wrong. In fact I'm getting 170V and -170V coming off of the bridge rectifier ( D602 ) and that voltage is making it's way all the way to IC601. I don't have any reference values in the specs or when it was working right, but the voltages on the big caps are also 170V and -170V.
                            These are what the pins on IC601 should read -
                            B1 - -1.1V
                            C1 - 153V
                            E1 - ?
                            B2 - 151V
                            C2 - 298V
                            E2 - 152V
                            Here is what they are actually reading -
                            B1 - -170V
                            C1 - 21V
                            E1 - -170V
                            B2 - 17V
                            C2 - 170V
                            E2 - 21V
                            Also, the voltages on C1, B2 and E2 are all very erratic, jumping up and down by about 1V.
                            One other interesting thing, the entire AC white line heading back to the AC plug from the bridge rectifier (D602 - pin 3) is .01V AC. Shouldn't this be 120V like the black line?
                            • R_J
                              • 9582
                              You need to know the difference between the HOT (primary side) of the power supply, and the COLD (chassis) side. They are marked on the board and the two sides are separated by a white line. When checking voltages on the HOT side you MUST use the negative pin of the bridge rectifier for your meter negative probe. You can not use chassis ground when checking primary voltages.
                              • cmonkey
                                • Apr 2023
                                • 58
                                • Unitied States
                                Yes I'm very careful with the hot and cold side, it's clearly marked. Could I also use the negative pin on the AC connector coming in from the electrical cord? This is what I've been doing.
                                Also, the negative pin of the bridge rectifier is not showing any voltage and this doesn't seem right to me. Maybe I'm not understanding but I thought voltage should be 120 from that pin going back to the AC in.
                                • Diah
                                  • Feb 2013
                                  • 6425
                                  this is wrong... use the - pins of large main caps of hot area as reference measurements at hot area only.
                                  SMPS will go high only if there power ON signal >3.v syncs to hot area via optocoupler .. if this optocoupler​ cut off the tv will never turn on.
                                  • cmonkey
                                    • Apr 2023
                                    • 58
                                    • Unitied States
                                    The power-on pin is 3.62V and the standby pins is 4.98V, so these two are good.
                                    • Diah
                                      • Feb 2013
                                      • 6425
                                      test the optocoupler of Power on between cold and hot out side the circuit
                                      • Diah
                                        • Feb 2013
                                        • 6425
                                        i think yours hot circuit are fine.... you need to follow and trouble shooting the cold circuit from power on pins till the optocoupler rail... could be changed value from low to high or open
                                        • cmonkey
                                          Sony Trinitron KV32FV27 Suddenly Dimmed
                                          by cmonkey
                                          A couple of days ago I finally got my hands on a locally sourced Trinitron and after lugging all 175 LBS home I gave it a good cleaning inside and out. The guy said it had been in a shed for 2 years, but the outside wasn't too bad. The inside was another story and while there was no evidence of mouse, it had certainly been kept in a VERY dirty home.
                                          I cleaned it to an acceptable level of grime, at least clean enough to where nothing would heat up from the dust insulation. I then tried it out and it worked!
                                          I'd say I had it on for about 15 minutes or so and then lugged...
                                          04-28-2023, 06:25 PM
                                        • motorahead
                                          Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
                                          by motorahead
                                          Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
                                          After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
                                          10-21-2023, 03:50 PM
                                        • ptcriserx3
                                          Sony trinitron crt bowed and side color issues
                                          by ptcriserx3
                                          Hi
                                          Ive got a vintage 2001 sony trinitron flat tube tv
                                          The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                                          See many images attached...
                                          Just windering if this is not fixable or something i can correct without getting too invloved
                                          Im trying to sell the tv
                                          06-17-2023, 07:27 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • sickboy
                                          Strange CRT Fault (Sony Trinitron M1410U)
                                          by sickboy
                                          This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
                                          11-10-2024, 05:02 AM
