Vizio 32" LCD Yellow Ting to screen but menu colors proper
  • Brentsky
    • Oct 2013
    • 46
    So I have a 32" Vizio L32 LCD that has a yellow tint to the screen when anything is plugged into it but I notice if i hit the menu those colors come up crisp and proper without yellow tint.
    Can someone give me a pointer on where to begin to look for and solve the problem. it's a Vizio L32
    Re: Vizio 32" LCD Yellow Ting to screen but menu colors proper
    Checked obvious - user menu TINT setting?
    • Brentsky
      • Oct 2013
      • 46
      Hey Tom66 thanks for always being willing to help. (I didn't get an email when you replied so I didn't get back to you and haven;t felt well lately so hadn't even tried at following up on this TV I just set it off to the side.
      Yes I had checked the user menu and color settings. This morning I found instructions on entering the service menu for it and in the service menu all were set to 128 except for Blue which was set to 0 I set it to 128 and exited the menu and the picture is now looking proper.
      Instructions in case anyone else runs into something like this are
      L32
      With power off, hold Ch UP and Ch Down together for 10 seconds.
      While still holding Ch up and down together, push power, then let go.
      Select OSD button, there should be a letter "F" in the lower right hand corner of the menu.
      Then hold OSD and Mute/Exit buttons together until factory menu comes up. Make adjustments with remote, select exit, then turn off power to save the adjustments.
      • freakaftr8
        • Oct 2012
        • 3743
        Good to hear. Vizio mainboards seem like they like to glitch for no reason, second to Samsung...
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • JaquesPratt
          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
          by JaquesPratt
          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
          07-16-2024, 01:04 AM
        • ARGO
          Vizio service menu code
          by ARGO
          There are a lot of different codes on internet but they doesn't work for all modern Vizio TVs.
          Here is tested code to enter service menu (factory menu), tested by me on D-series and P-series:
          MENU-1-9-9-9-Return.
          (Retun is a button with round arrow on remote)
          Overall the menu is useless because it doesn't allow to change panel and LVDS settings...
          If anybody knows any other codes for Vizio, post it here, please.
          By the way, Philips TVs uses the same main boards with same service menu access code......
          06-10-2020, 08:16 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
