Samsung LNR408DX Negative Picture After TConn Replacement
  • CrypticOne
    Lone Gun Man
    • Jan 2014
    • 14
    Re: Samsung LNR408DX Negative Picture After TConn Replacement
    Originally posted by Glitcher
    Did you test the fuse on the new tcon before or after you placed it in your panel? Theres a chance that your panel may be causing the fuse to blow just as in your original tcon board. I would say you probably have a bad panel causing the fuse to short.
    Sadly it tested bad out of the box from RetechTV. I have left a bunch of messages but they have yet to return any calls.
    Cryptic
    • CrypticOne
      Lone Gun Man
      • Jan 2014
      • 14
      Originally posted by tom66
      VONE and VOFF are both OK. Not sure what else to suggest. Gamma voltages are a little iffy, but might be OK for this panel.
      I am going to try ordering from a different vendor and see what my results are.
      • Goldenmonkey
        Samsung pn59d530a3f no picture after power supply replacement
        by Goldenmonkey
        My samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
        after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
        Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
        04-07-2023, 09:39 AM
        09-07-2024, 05:50 AM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
      • YellowJacket
        Samsung QE55Q60RAT - no picture
        by YellowJacket
        Hi friends,
        a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
        07-30-2024, 01:31 PM
