samsung 32 UE32D400
    Re: samsung 32 UE32D400
    That waveform confirms main board is sending video data, so my thinking is something on that bonded t-con board is bad, meaning the panel is bad. You might be able to find some way of harvesting the t-con from a scrap screen, perhaps via very careful re-bonding of that single tab (since there's only one to line up, it's marginally easier.)
    • adamp91gvm
      • Jan 2014
      • 706
      • uk
      #62
      How are they stuck down
        Soldered I believe; you could try solder paste, but you'd need a precise stencil or a lot of patience . One other possibility is anisotropically conductive tape - it's tape which conducts only in one direction, allowing you to attach a ribbon with a piece of tape. 3M has -Z-Axis tape which is suitable for this application. However, as far as I know, no one has succeeded in doing this, yet.
        You could be the first
        • adamp91gvm
          • Jan 2014
          • 706
          • uk
          #64
          Guttered about this tv it looks spanking new inside and out
            Well, that's modern LED TVs for you. Reliability is terrible.
            • adamp91gvm
              • Jan 2014
              • 706
              • uk
              #66
              Yup I think I'll start on a 42 inch lg I have with no pic tomorrow put this under my bed and forget about it for a bit
              • adamp91gvm
                • Jan 2014
                • 706
                • uk
                #67
                I'm not giving up in this lol I'm getting power to the left side as I look at it but from here I'm getting nothing from anywhere on this the 220 one
                  That seems normal for that configuration, as one end is grounded. Possibly VGL generation circuit (negative.) It's often not abnormal to get significant voltage drops across components. Electronics would be awful simple if everything worked at V+ or 0V...
                  • adamp91gvm
                    • Jan 2014
                    • 706
                    • uk
                    #69
                    Ha ha I know I just really want to get this going
                      Yeah I've been seeing quite a few 32" 720p Samsung panels dying. I am interested in fixing one at some point, but I really need to have one in my hands, probing everything, to find the fault. Maybe there's some easy, obvious fault, but I'm not seeing it.
                      • adamp91gvm
                        • Jan 2014
                        • 706
                        • uk
                        #71
                        I know it's going to be something stupid that's what's getting me
                        • adamp91gvm
                          • Jan 2014
                          • 706
                          • uk
                          #72
                          Stupid question time this next to the fuse is getting 12v ish into it but nothing from the other side is it suppose to ?
                            It is a TVS surge protector. It shunts higher voltage transients to ground. It's an odd device in that position, I'm guessing it might be useful for some of the more inventive power supplies that we're seeing in cheap TVs which are horribly unregulated and could damage a normal T-con over time. I suppose since it's such a cheap device it's just some insurance for Samsung.
                            One end is grounded so you will see nothing "out" of it. That is how it works.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Is it a diode ? Remove power and test it to see which way it should be conducting.
                              • mmartell
                                • Oct 2013
                                • 3189
                                Oops nm tom is on it
                                  Note: mmartell is correct... it could be a diode too, for reverse polarity protection, but that's really odd, only a wiring harness error would cause that and it would still blow the fuse rendering the module "failed" to most manufacturers... A TVS is also a diode. Just with a low voltage breakdown designed in.
                                  • adamp91gvm
                                    • Jan 2014
                                    • 706
                                    • uk
                                    #77
                                    If I just un clip the ribbon to it and move it slightly I get a bunch of lines on the screen like black and white
                                      Do you notice any change on VOFFE/VONE when doing this?
                                      I think it is a fault on that t-con board, but no schematic and no datasheet for the parts, it's hard to narrow it down.
                                      • adamp91gvm
                                        • Jan 2014
                                        • 706
                                        • uk
                                        #79
                                        Would samsung have the schematic diagrams if I ring them
                                          No... I've never found one for LCD T-con except one old 26" AUO panel which is pretty different to newer panel.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
