LG 42PT350 Won't Turn On. YSUS Shorted. Bad buffer too?
  • johnboy1313
    • Nov 2012
    • 1959
    I opened this one up this afternoon. It wouldn't turn on. Red indicator light at standby. When you power the set on, the LED would shut off for a second them come back on and stay on. The set would never power on. I opened it up and got it to power up with the Y-Sus unplugged. It has the EBR68341901 YSUS board and the EBR68288401 buffer board. I found 3 bad 30f124 and 2 bad IRG71C28U transistors. Will a test for shorts between the connectors on each side work like on a Samsung buffer?
    Also, I didn't notice it at first, but the control board has an LED on it that appears to be flashing a code at me. You be the judge.
    https://www.youtube.com/watch?v=bKssQwzOeBk
    Pics.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: LG 42PT350 Won't Turn On. YSUS Shorted. Bad buffer too?
    What do you suppose took out the transistors in the first place? Do you think I'll be able to replace just those bad components and get away with it?
      Bad buffer nowadays would rarely cause Y-sus failure. But, the test would be similar. When replacing those IGBTs I'd also consider replacing the driver chip for them.
      You could run the Y-sus without those IGBTs in place, then see if you get -Vy and Vsc. If those voltages are OK when the buffers are connected, then the buffers are not bad.
      • johnboy1313
        • Nov 2012
        • 1959
        And if the set powers on, the driver chips are ok?
        • legg
          LG 42PC3 buffer output doesn't follow YSUS
          by legg
          LG42PC3D -UD originally with green lamp but no display or audio.
          Owner says was working, then went 'pop'.
          All 5V caps bulging. replaced.
          All PSU output voltages within spec but -Vy is low on YSUS.
          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
          eventually shorts DG. Replaced all 3 - -Vy now OK.
          Y scan buffer test point does not follow YSUS output below -50V
          Note: This unit seems to expect YSUS output to park at -Vy in between
          drive signal pattern periods. A replacement drive signal board confirms this....
          11-18-2021, 11:49 AM
        • Satdude
          Xbox 360E won't turn on after voltage regulator shorted
          by Satdude
          Hello, I have a Xbox 360E Stingray where the 3.3VSTB regulator shorted and put 5V on the rail. I think the RAM and eMMC are on this rail. After replacing the regulátor, I get proper 3.3V but the console won't even turn on. Seems the eMMC is dead, I get power to it just fine but JRunner doesn't even detect the console when I hook up my PicoFlasher. Does a dead eMMC/NAND cause the console to not even turn on? Also does this with the eMMC removed, planning to downgrade it to 16MB NAND but want to know if it's a useless effort to save this motherboard. Thanks
          08-28-2024, 03:55 PM
        • im_trying
          MSI GF65 Thin doesn't turn on, shorted on dc-in, how to find the culprit?
          by im_trying
          Hi, thanks for helping.
          The motherboard is from a gaming laptop, msi gf65 thin 10ue, 16W21/11S.
          For starters, it doesn't power on. I measured a "short" on the second DC-IN mosfet, right around the charging port but I don't know how to find the component that's shorting it.
          I already tried checking the mosfet for internal shortage (by desoldering and measuring) but no short. The drain on the motherboard is the one that's shorted, next to the gate (that's not shorted).
          The photo below shows this better than words.
          Thanks for anyone...
          05-12-2025, 04:16 AM
        • reessi
          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
          by reessi
          Hello:
          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
          I started on the ACER:
          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
          10-29-2024, 11:31 AM
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
