Another LCD Tv That did not go to the land fill
    • Jul 2011
    • 6070
    The story about this TV
    It is a Emerson 19" with a DVD player model # LD195EM8
    The person who gave it to me said that one side of the picture would be red when you first turn ON then after awhile would be normal but it was getting worst and some it just stay on that one side
    I did even turn the set on I just start checking all of the caps
    The caps that had a value of 220uf and higher for the most part had a ESR reading that was normal
    However the caps that were below 220uf to 100uf those ESR reading were a on the high side compare to a new one
    The real problem was with caps that were from .47uf to 47uf these caps had a
    ESR value that was 10 to 20 times the value of a new one there was about 30 of them
    Here is an example of one them a new one had a reading of .34 ESR reading and old one had a reading of 5.0
    The main power cap and a few caps that was part of the sound circuit were not replace I for got to order them
    This LCD TV board was a real pain in the @ss to do because of the fact that there was so many caps to replace about 60 of them
    Now this LCD TV has a very good picture in fact I am watching right now and I also watched a DVD disk and it also worked very well
    I am not going to keep this TV set that I got from some one at work
    I am going to give to some one that I work with at work
    who has been some welding on my barbecue grill
  • mmartell
    • Oct 2013
    • 3189
    Re: Another LCD Tv That did not go to the land fill
    Good story and good outcome.
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
