My newest project, an LG 47LC7DF, look what I found.
  • lookimback
    • Aug 2013
    • 1489
    The problem is bad caps on the power supply and I suspected that before I got the TV. Its a common problem with this model. When I opened it up, I found that it had been worked on before and a couple caps had been replaced with what looks like Radio Shack caps.
    I'll be replacing the 9 caps which I marked with the red dots in the first pic. 5 of them are 10v 2200uf but I think its common practice on this model to upgrade them to 25v 2200uf. That's what I'll be doing.
    ------------signature starts here------------
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: My newest project, an LG 47LC7DF, look what I found.
    and those 5 caps you mention,have been fails on this psu for me also,uprate 2200uf10v,to 25v,you can be sure by checking dc voltage across those caps on board,they rate them too low
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      and that axial leaded cap leg looks awful close to the standby transformer!
      • lookimback
        • Aug 2013
        • 1489
        Those are the Radio Shack ones. They're coming out and being replaced with radials. And I had suspected that those caps should be uprated. I hadn't found anything specifically saying it, but had noticed it being done in a couple YouTube videos.
          They don't need uprating. LG used 10V capacitors on the 5V and 6V rails, and 16V capacitors on the 12V rail - which is sufficient.
          The originals were just shit caps (Samwha WB, Samwha XC.)
          • lookimback
            • Aug 2013
            • 1489
            I'll go with the same as the originals then. Thanks Tom.
            • lookimback
              • Aug 2013
              • 1489
              So I could actually put a meter across the caps and determine, based on the voltage, whether the caps are sufficiently rated. I've learned something here. Thanks.
                You could also trace the SMPS output and see which labels correspond to what pins.
                • lookimback
                  • Aug 2013
                  • 1489
                  OK, that makes sense.
                  • lookimback
                    • Aug 2013
                    • 1489
                    I replaced those 9 caps and it's fixed. I've decided I'm keeping this one for myself and selling my 40" Sony Bravia that I've been using since I fixed it in mid September last year. Here's a pic of the repair. Looks much better now. Thanks again to everyone who helped.
