Samsung Plasma PN50A550
  • powers
    • Jan 2014
    • 5
    • usa
    I have a Samsung plasma PN50A550 that seems to have similar problems as posted else where, but not with the simple solutions. It cycles and flickers on and off for 15-20 minutes, making clicking sound every time it automatically turns on and off, makes a very loud screeching sound, until the picture finally clears up, then it works just fine. I took a look at the capacitors and none of them appear bulging, all the soldering looks fine on the back of the boards. Any suggestions? I've read about reflowing the main board but don't know how or if this is even safe.
    Re: Samsung Plasma PN50A550
    There's an issue with a capacitor on the main board under the RAM chips causing this problem, will try and find the thread. It's a surface mount tantalum, yellow or black in colour.
    • burnvictim
      • Jan 2014
      • 4
      Hi Tom, I'm having the same issue with my main board...if I heat the board a bit the TV comes on as normal. When cold it does the start up cycling bit till it gets warm and then starts up. I have been using a hair dryer to kick start it but if I knew which cap to replace, that would be fantastic. Did you happen to find the thread about the cap below the memory chips? Any chance you know the cap # i.e. C271?
      I would be grateful for any help
      Jeff
        This is the thread.
        https://www.badcaps.net/forum/showth...t=32061&page=2
        • powers
          • Jan 2014
          • 5
          • usa
          Has this worked for anyone else? That tantalum capacitor C102 is tiny. I'm ordering this part today to try (its only $1.39). I have been resorting to a blow dryer to help warm the board up to turn on faster, its works but is annoying.
            You can see 3 users in that thread with this problem that it appeared to fix.
            • powers
              • Jan 2014
              • 5
              • usa
              Replacing the C102 tantalum capacitor worked like a charm. Easy to remove and resolder. TV turned right on! No more on/off, clicking, or having to warm up the board with a blow dryer. Turns on right away. Great fix for $1.50 replacement part. Thanks to everyone posting here.
              • stegagne
                • Jun 2015
                • canada
                Hello guys,
                Thank you for the great advices.
                Our PN50A550 was doing the clicking of death.
                So I changed the c102, and 2-3 on the power supply board without success.
                There was almost no voltage at the output of the psu to the logic board. (0.xxx v.)
                After a while I checked the fuses... which I should have done first. There are 3 fuses. The top center one was blown out.
                Replaced the fuse and tv work jusg fine.
                I will order another c102 cap exact model in case for the future.
                I replaced both 330uf on the left and 1x 820uf capacitors on the psu.
                Regards
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  The cap everybody is talking about is located on the main board(where the hdmi inputs are mounted on).
                  • Dough222
                    • Nov 2017
                    • US
                    Could you send a pic? I'm having a hard time finding it.. Could be a little bad vision going on.
                    • jetadm123
                      • 2169
                      Tom66 provides a link to the photo/cap in post #4. If you still do not see it, then you may have a different mainboard. Good focused photos of YOUR board may help.
                      • tvtimmy
                        • Mar 2015
                        • 1160
                        • usa
                        Here it is.
                        It is a 47uf tantalum capacitor. I think the voltage is 10v.
                        • Samsung TVs Suck
                          • Nov 2017
                          We had the same issue. We replaced mother board and a capacitor and it fixed the issue. There was an actual service bulletin on the capacitor.
                          • Samsung TVs Suck
                            • Nov 2017
                            We fixed the cycling and clicking issue but now we have 2 thin lines (mainly red and blue in color) on the far left hand side that showed up 6 months after 2nd mother board replacement plus the new capacitor. This TV is only 2-3 years old and been problematic since it was 6 months old.
                            65” Samsung Plasma
                            Model: PN50A550
                            • aaronwt6
                              • Apr 2013
                              • 855
                              • US
                              65” Samsung Plasma
                              Model: PN50A550
                              This looks like an LED TV to me. I'd check your model number but that's almost certainly a screen failure (not fixable).
                                It's a plasma TV, and it's a defective screen unfortunately.
                                • aaronwt6
                                  • Apr 2013
                                  • 855
                                  • US
                                  I've never seen a Samsung plasma with that bezel before. It confused me.
                                    09-07-2024, 05:50 AM
                                    09-06-2024, 11:40 PM
                                    09-06-2024, 08:40 PM
                                    09-06-2024, 06:20 PM
