Re: Panasonic Plasma TV LED blinking 12 times
No real idea, just wild guesses. Is there 15V at pin 8 of MC701 . Micro fuse IP351 on the underside, ?
Typo: Should have been 15v at D and no 15v at SLeave a comment:
TP2302 does indeed go high to flag the SOS.
I nonitored the G-S voltage of mosfet Q351 with a scope, this never rose above a fraction of a volt during switch on & just looked like noise. This obviousy isn't sufficient to turn the device on hence 15v at D and no 15v at D.
I then monitored pin 4 of MC351 which is marked 15V_ON, which i assume is the signal to turn Q351 on, this remained constantly 0. This in turn comes from MC701.
I am probably at the point now where I am beginning to condider that I'll have to replace the power board, unless anyone has any suggestions.Leave a comment:
I stopped short of suggesting that, all I know is once you have them , they never seem strong enough.
Don't worry, someone else would have pointed it out. The fact 2 of us posted 2SK2510, you had me wondering especially with the , can't find the datasheet comment.
Doh,
Sorry, will have to get some glasses. even when I saw it in your message I read it as 5 instead of S. Good job there is someone around to put me right.Leave a comment:
if you keep typing 25K2510 when it's 2SK2510, you won't. i get a page full of hits, the first being a spec sheet.The voltage increases gradually over a couple of seconds and reaches a max of 1.56v which is steady for probably about a second then shuts off. Will do the test again and take better note of what happens. tw2005 I agree with what you are saying, I'll check out Q2301.
I did identify the FET as 25K2510, I just can't seem to find a data sheet for it to see it's spec in case it is faulty and need to find an equivalent.
Thanks for the help guys.
One would think if it takes 2 secs to get to 1.56v, holds for a sec then shutdown, PSU fault is looking likely.
Did a quick search here for equivalents http://alltransistors.com/mosfet/crs...024&caps=MP45F
2SK2498, 2SK2512
Type Designator: 2SK2510
Type of 2SK2510 transistor: MOSFET
Type of control channel: N -Channel
Maximum power dissipation (Pd), W: 35
Maximum drain-source voltage |Uds|, V: 60
Maximum drain current |Id|, A: 40
Maximum junction temperature (Tj), °C: 150
Maximum drain-source on-state resistance (Rds), Ohm: 0.024
Package: MP45FLast edited by tw2005; 01-23-2014, 02:41 AM.Leave a comment:
Thanks for the help guys.Leave a comment:
Don't forget you have the SM. As per Tom's response. Q351 search in the PDF gives you 2SK2510.Further tests show that I have 15v at TP7 which is upstream of Q351 FET which appears to switch the 15v to P6 pins 1-4. I plan to investigate further at the weekend when I can borrow a probe from work which is small enough to get onto the gate to see if the gate drive is ok.
I have not yet been able to identify the FET from it's number NEC 25K2510.
There's actually a lot of true part numbers in there unlike the later manuals where they get Panasonic coded numbers which are meaningless most of the time.Leave a comment:
I was wonder looking at the diagrams, looks like this PSU has those modules (MC351)similar to that in the 46PZ800 and others which had 2 & 10 blink issues generally due to a bad ceramic cap on the module?
I believe they were loss of 15V related too.
Edit: but then you did say you have 15V, keep digging, hope you find the culprit.Last edited by tw2005; 01-22-2014, 06:59 PM.Leave a comment:
Maybe, how long after the 1.56 does it shutdown? Is it a steady 1.56 or rising when it kills.
The other thing I'm looking at is Q2301 and test point TP2301, I suspect gose high on the SOS.
I guess what we really need is either to figure a way to test the voltages from the PSU as if the TV was running or I'm thinking if TP2301 if it's high on the trip, earthing that out and see if the TV powers up with no blinks.
Then recheck the voltage.
There's probably a more correct way, is there anything in the other post that helps.
Both H boards are doing the same assuming both are good suggesting the problem is elsewhere.
I don't want to say it's the PSU unless it's proven the 15V_S can't be generated.Leave a comment:
I have not yet been able to identify the FET from it's number NEC 25K2510.Leave a comment:
I've done the tests as you suggested and at H3 pins 21-23 & P6 pins 2-4 the voltage only rises to 1.56v max before it is tripped off. Looks like it could be the +15v from the P board? I assume this voltaage is reference to the chassis ground?Leave a comment:
Thanks for the reply, yes you are absolutely right about the boards. I'll do the checks you suggested and hope I can trace the board where the fault is. Thanks for the link to the manual, it's a great help, was trying to use a manual for a similar set but had an A board instead of the H & DG boards which is why I replaced them both.
If it's the P board I can get a replacement but want to be sure before I go ahead, looks like I've already replaced 2 unnecessarily.
Thanks again for taking the trouble to help.Leave a comment:
So there is no A-board, but DG(TNPA4226), H (TNPA4177), D (TNPA4133), PA(TNPA4178).
Maybe download the service manual
See if you can check +15V_S is going to the H board at H3 pins 21-23, delivered from PSU P6 pins 2-4 via PA board, in PA6, out PA3 , in H3
H board IC2301 needs Sound15V, Sound12V. Sound12V is generated from the Sound15V(+15V_S) by the voltage regulator IC2303.
It appears IC2301 generates the SOS, and a high is operate, a low is SOS so i guess if there was no 15V that would mean a low from that and trip the SOS12.
I've got no experience with this generation so I'm just going by the schematic since there's no mention of any voltage checks.
It may be the case that you will have to hook up the probes first and then power on to detect the 15V because I expect SOS12 will kill the 15V when tripped.
There was another post for similar problem with no result unfortunately.
https://www.badcaps.net/forum/showth...hlight=50PX70B
Manual shows P or H board as first checkpoints in the blink chart.Last edited by tw2005; 01-21-2014, 04:55 PM.Leave a comment:
I've just replaced the A board (2 boards to be exact TNPA4177 and TNPA4226) and the problem is still the same, ie 12 blinks. Any ideas where the problem can be now?Leave a comment:
TW2005,
You are correct that the part number is TXN/A1EFUUS and the board number is TNPH07861A. There is no suffix that I can tell. Pictures are attached of the board numbers I find and the panel info.Attached Filesif you find these attachements useful please consider making a small donation to the site
I'd stick to
TXN/A1EFUUS or TNPH0786 no suffix. There's a matrix on the PCB above the TNPH0786 number. The suffix is determined by the placement of 5 jumpers above that table which you decode looking at the dots labelled in the matrix.
SJ says yours has no suffix which I suspect means there'll be no jumpers.
The AF is a 46" panel.
42U1, version AE I suspect would work however A30 is missing for the fans.
So it should work as they have the same panel, you won't have fans running.
That's what I see at a glance.Leave a comment:
by SLB007I get no image nor backlight, standby light blinks 13 times then stops. Any clues what it could be no evidence of damaged components11-02-2025, 04:08 PM
by ahmarzoI have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery... -
by YasaChHello...
my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
i opened the back cover no sign of damage on the powery suply or motherboard
when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites2 Photos -
by RictechHello everyone. 😀
As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
There are no devices that have exploded or otherwise show signs...-
by fourroses73Hi all folks.
My old Plasma TV blinks 10 Times when i try to start it. Its now 2 weeks that i search like an old donkey on internet and i try everything.
Nothing smell or looks like burned. I think its the A board, but i did not find more infos how search error on the A board. Replace it its not an option: I dont find part for this TV in my country and if i give it to a repair shop its to expensiv...
What i have measured:
Vsus and Vda are ok
Pin1 of connector P7 : 5V ok
Pin1 and 9 of connector P6: 16V in place of 15V but... - Loading...
