Samsung LN40A550 corrupted image
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this TV with supposedly green image.
    It worked for me well for over a week.
    I thought that is all well. Now when I was ready to sell it, the image got corrupted at bootup. It restarts a couple of times, until the image is good.
    Sometimes it makes the screeching sound with the corrupted image. This sounds as a mainboard fault.
    There it could be other issues as well? Capacitors maybe?
    I have the same TV in my bedroom which works well after replacing capacitors in it. The panel is marked differently in the service menu.
    Re: Samsung LN40A550 corrupted image
    Main board BGA/ bad RAM, typically. Could also be a bad tantalum capacitor near CPU/RAM.
    • tw2005
      • Oct 2011
      • 6458
      I've had something similar on a chinese cheapie 32" LCD. TV would run for random periods then suddenly screeching noises, green screen, messed up picture all scrambled and locked up.
      That was dirty 5V rail from memory on the PSU, bad 100uf cap, well actually the cap was ok, the soldering was not. Was not soldered correctly, dry joint. That was an easy fix.
      So bad cap / dirty power could be a possibility.
      • tibimakai
        • Jan 2012
        • 3680
        Found two 1000uF/50V capacitors at the output on the power supply, that somebody already replaced with the wrong capacitors.
        One of them had high ESR, the other one seemed fine.
        Replaced them with correct Panasonic ones.
        Right now, it seems like it's working great. I will monitor it for the next couple of days.
          09-07-2024, 05:50 AM
        • shlomim412
          samsung ua55es6800 - no image
          by shlomim412
          hi
          having problem with samsung ua55es6800
          tv had backlight on, sound working - responds to the remote control but no image.
          check tcon board - had 12v in but no other voltages present.
          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
          when leaving only left side connected - again no voltages and no image.
          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
          kept trying to block less pins on the left ribbon cable...
          05-15-2024, 05:00 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
