Dynex - DX-55L150A11 Sound issue
  • SolderMaster
    • Dec 2013
    • 53
    First time poster, long time lurker...
    This unit works fine until you turn up the volume and the bass in the audio settings. The unit will shut down after a few seconds at high volume.
    Another tech replaced the main board. Then I got the call. I replaced the power board and the speakers. Still have the same issue.
    When I replaced the power board and powered up, there was a very noticable hiss coming from the T-Con. I swapped boards again and the hiss went away.
    Is it possible something on the T-Con or the panel is causing this unit to crash when the volume and bass is turned up? Maybe a vibration short of some kind? Sorry, no pictures for this unit.
  • benspawn02
    Anthem MRX500 - no sound. R2A15218FP issue??
    by benspawn02
    Dear Electronics Experts:
    I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
    08-12-2023, 04:46 AM
  • ctebke
    DELL 3501 MB la-k034p Sound issue
    by ctebke
    Hello, I have dell 3501 MB la-k034p with Sound issue RED cross. No sound device in device manager. In BIOS diagnostic everything passes but no sound tone either in bios test. AUDIO chip is CS42l42 and 3.3v, 1.8v is present. Someone have any idea ? Thanks.
    11-21-2025, 08:09 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • ex250
    Kenwood SW-505D no sound issue and pops from time to time when it works
    by ex250
    Hello mates,
    I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
    It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
    12-29-2024, 03:27 PM
  • saisoni20
    MacBook Air A2337 820-02016-07 No sound ISSUE
    by saisoni20
    I have A2337 MacBook Air no sound issue.
    I have replaced new Audio Board but still same issue. I went through repair wiki and checked critical voltages.
    In terms of voltages, I have following voltages,
    1 PP1V25_AWAKE_IO - 1.2V
    2 PP1V25_AWAKE_IO - 1.8V
    3 SPKRAMP_A_OUTP_R - 0V
    ​4 SPKRAMP_A_OUTN_R - 0V
    Am I missing any other critical voltages?
    07-28-2024, 05:53 PM
