How to find the serial communication location of Sony TV KD-55X8000C motherboard to read printing information
  • yangliao
    • Jan 2024
    • 6
    • china
    Hello everyone, I met a Sony motherboard KD
    -55X8000C model, the serial port location cannot be found. I want to read the printing information through the serial port. I don't know if this idea is feasible. I hope friends who know more can answer it to clear up my doubts. Thank you in advance!​
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4521
    • Italy - Milan
    Near the optical out there are 4 pads in a row, gnd, rx, tx, 5v (swap rx,tx eventually)
    • yangliao
      • Jan 2024
      • 6
      • china
      Hello, I wired the wiring according to this diagram, but the mainboard and the programmer cannot communicate. I don’t know which link is the problem.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4521
        • Italy - Milan
        yes, of course, big error, you must always connect gnd wire.. , again try first, if no go swap tx,rx..first speed to try is 115200bps then decrease if necessary
        • Diah
          • Feb 2013
          • 6502
          Wrong wiring and location .. UART RX / TX always connected to R.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4521
            • Italy - Milan
            why you tinned the 5v+ pole? it is not needed..
            • N33k0
              Apple M1 Pro and Max Serial Number location on MLB?
              by N33k0
              I think by now, everyone who is in Apple repair has read the other long post about this topic. Unfortunately, that thread was closed back in December of last year and went unresolved. Are there any updates or new info as to where the serial number appears to be located on these boards? The last major update for that thread was the the serial appears to be stored on a section of the NAND but no tools existed yet to read and write from that portion of the drive.
              It would be nice to get this discussion going again.
              06-26-2023, 07:05 AM
            • Carlos#2003%
              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
              by Carlos#2003%
              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
              02-15-2024, 07:52 PM
            • bruce35
              HP 600 G3 MT serial number change please
              by bruce35
              HP 600 G3 MT
              SERIAL NUMBER MXL8301K1C Serial number in the file in bios
              SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
              Thank you very much...
              09-24-2025, 02:32 AM
            • dkneyle
              Sony KDL-46HX850 Can't upgrade/update firmware
              by dkneyle
              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
              09-25-2024, 10:44 PM
              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 05:27 AM
