Samsung PS43D490 red pink snow
  • homerclone
    • Jan 2014
    • 53
    My First Thread :-)
    Hope this has not been asked before (I did a search but could not find anything)
    I have a Samsung ps43d490 3d tv and it started to show a pink/red pixel snow all over the screen.(please see pictures)
    I went to Samsung website and installed the latest firmware for tv by usb but this had no effect.
    I removed the rear cover from tv and read the vs/vscan settings for tv
    should be va-58 vsc-185 vs-207
    now to get rid of the snow I had to alter these settings to-
    va-58 vsc-206.4 vs-209 and im getting a good picture.
    My questions are
    1. will this cause damage to tv by raising the settings?
    2. is it week capacitors that causing me to raise these settings?
    3. should I just change the boards?
    Thanks for your time guys and girls :-)
    Last edited by homerclone; 01-04-2014, 05:20 AM. Reason: needed to add the girls bit
    Re: Samsung PS43D490 red pink snow
    I would avoid setting Vsc so high; can you check what Ve measures? It's on X-main board.
    • homerclone
      • Jan 2014
      • 53
      Hi tom
      Thanks for your reply but I cant see a test point marked ve?
      on label it says ve = 0 ?
      I sent pic of board I think is x-main (im a computer tech not tv tech so I might be a bit slow on this)
      • homerclone
        • Jan 2014
        • 53
        sorry tome I see ve on pin no.4 of grey cables going out the board 106.6 v
        Does this help
          Ve = 0 means it's a free voltage (unspecified) not 0V. Confusing!
          I would try upping Vs to 211V and dropping -Vsc to the lowest point of misfire. It is a known issue with Samsung panels (red diffusion.) Increasing -Vsc may damage Y-buffer board.
          • homerclone
            • Jan 2014
            • 53
            Thanks tom
            Ve is showing 106.6v on terminal
            Do you think replacing X & Y board would fix the issue or maybe is should order them in just in case it blows a board ?
            Thank for your time
            Mark
              Ve is OK, that is within range (80~120V.)
              • homerclone
                • Jan 2014
                • 53
                Thanks very Much tom
                I have raised vs to 211 but I cant drop vsc the pink snow gets worse on a green screen.
                If I change the x & y board do you think this will cure it?
                would I also need power board?
                Thanks for you time you are most helpful
                  I do not think changing the X/Y-main will help. I think you will just have to set -Vsc to as low as possible and hope it does not fail, really strange though. Did you apply the Samsung "Red Diffusion" update? What software version is the TV running? I can't help but think the problem will get worse over time and you will need to increase -Vsc more until the buffer board is possibly damaged.
                  • homerclone
                    • Jan 2014
                    • 53
                    firmware version
                    1029.0 Upgrade File(USB type) 11 Dec, 2013
                    cant see the Samsung "Red Diffusion" update?
                    Hope this helps
                    shame I really like the picture on this Samsung and don't want to change it
                      Sorry, my error, red diffusion is for C450 series. Seems like you will have to leave it as it is.
                      • homerclone
                        • Jan 2014
                        • 53
                        Just a quick update. I ordered new x-main and y-main boards from PARTS4U both boards sent were faulty :-( .Cant get hold of them as they do not reply to my emails or phone messages. So I order some more boards from eBay seller sivill123 He was very helpful and sent boards to me the next day. I have fitted the boards and set the vscan and vs setting to the settings labelled on back of tv.
                        The tv is now working fine.
                        I am well happy :-)
                        Big shout out to and very big thumbs up to sivill123 and a very big thumbs down to PARTS4u.me
                        • jbfr_54
                          • Dec 2012
                          • 52
                          • France
                          I have yellow (mostly) and red sparkles on screen specially on dark images, all dependant of image content. Brilliant clear images (like a partly cloudy sky) do not show the snow.
                          Nominal voltages of panel are
                          Vscan -185
                          Vs 207
                          Va 57,6
                          Ve unmentioned
                          When the defect is showing I have measured
                          Vscan -183,6
                          Vs 206,1
                          Va 57,6
                          To get rid of the defect, I had to adjust to
                          Vscan 187,3
                          Vs 207,9
                          Va 59,6
                          Some sparkles still show, this is the very limit.
                          A better combination is
                          Vscan -186,1
                          Vs 210,4
                          Va 60,3
                          My question is about the risk for the panel or the Y-main / X-main or even X-address electronics.
                          What is the most dangerous voltage to increase ?
                          Thanks for any advice.
                          Jean
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:20 PM
                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
