digihome 32860fhd
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #41
    Re: digihome 32860fhd
    thats the problem he did not know mines a samsung panel so not sure if to order another tcon out of a digihome set only as the same voltages was missing on the new t con or is it a faulty main board?
      Same connector on both boards? Does one board label say, e.g. "CMO", "AUO", "LPL", "SAM", "CPT"...? (Chi Mei, AU Optronics, LG Philips LCD / LG Display, Samsung, Chungwha Picture Tubes.)
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #43
        exactly the same down to large ic numbers etc no difference at all no lables on them only the bar code stickers both have 32 inch mentioned on them.so i think the tcon may be interchangeable.
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
        • tonydix
          Digihome Vestel 500UNDC TV loses picture after a few seconds
          by tonydix
          Vestel 500UNDC using a vestel 17PS20 power board. Backlights come on and picture shows for a few seconds and then goes dark. Sound is fine. Is this a problem with the led strips or the backlight driver ? Many thanks
          11-15-2021, 05:37 AM
        • France_53
          Vestel tv, how to flip the image?
          by France_53
          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
          05-12-2024, 05:22 AM
        • Strudul
          Digihome 40272SM (Vestel) - Various Issues.
          by Strudul
          I've got a Digihome 40272SM with a number of problems, some of which appear to be intermittent.
          1) Initially, the problem was an intermittent dark patch on the left side of the screen and a single 1 pixel wide black vertical line on the right side. The dark patch seems to have fixed itself, but the black vertical line remains. I'm assuming this is due to a faulty panel, so will just have to live with it (it's not too invasive for the use it gets).
          2) Along with the above, the TV would turn itself off randomly. This only seemed to happen when the dark patch on the...
          04-06-2021, 12:53 PM
        • John McGivern
          Digihome PTDR32FHDS5 (Vestel) 32" LED Smart TV
          by John McGivern
          Above TV, power on, 8 flashes tested all diodes and electrolytic caps ok
          voltages shown on attached photo's. LEDs tested all but one was open so I bridged open LED all light but very dim. Shining torch I can see text on screen but voltage low on led connector. I dont have a remote yet. Any help would be appreciated.
          Many thanks....
          03-05-2022, 09:48 AM
