Troubleshooting LG TV 60UH8500. TV is not powering on
  • KKinNJ
    • Dec 2023
    • 7
    I'm new to this forum, so this is my first post. I have an LED TV LG Model 60UH8500 that stopped working suddenly. The standby LED is on, but when I try to turn the TV on either using the remote or the power button on the TV, the red standby LED blinks 3 times, but nothing else happens - the TV screen stays dark, no picture and no sound.
    Here is what I did so far... I removed the back cover and checked both the power supply board and the main board for any obvious visual cues such as burnt diodes, bulging caps, etc. Nothing observed. I checked 2 fuses - GOOD, tested all capacitors and diodes that I could - found nothing. I also tested the voltages at the following spots:
    In Standby mode:
    12V: 7.8V
    24V: 0V
    POWER_ON: 0V
    DRV_ON: 0V
    LED+: 43V
    After turning on:
    12V: 11.9V
    24V: 24.8V
    POWER_ON: 3.1V
    DRV_ON: 0V
    LED+: 63.7V
    โ€‹
    With the back cover removed I could observe that after 10 seconds or so after powering the TV on the amber LED on the power supply board LD701 blinks 5 times then off for about 5 seconds and then blinks 5 times and it repeats indefinitely. I think it's some kind of error code, but I couldn't find anything that would explain or narrow things down for me.
    I'm trying to narrow things down to either a power board, a main board or something else, to see if I could fix this or not. Any help with what I should test next would be appreciated.
  • KKinNJ
    • Dec 2023
    • 7
    Here are the pictures of the power supply board in case this helps...
      • 12200
      • U.S.
      Probably faulty mainboard, DRV_ON signal comes from mainboard, it's the backlight on signal.
        • 12200
        • U.S.
        I think for good measure, maybe touch up any suspect solder joints on powerboard: https://www.youtube.com/watch?v=5F4sX2Pn-Iw
        • KKinNJ
          • Dec 2023
          • 7
          That was my thinking too, but how can I be sure? Can I somehow exclude the possibility that this is the power supply? I tried bridging the POWER_ON to DRV_ON to see if the backlight comes on, but it didn't. I just don't want to buy a new main board without knowing it will fix the issue. Also, If it is the main board, is there a way to troubleshoot why it's not sending the DRV_ON signal?
          • EazyBone
            • Jun 2023
            • 1337
            • United states
            Have you tested the LEDs? That would be my obvious first thing to do?
            Have you turned on the TV and held a flashlight up to the screen and looked around to see if there is picture??
            Also how did you bridge pwr on and drv on? Main board connected or just standalone psu
            • KKinNJ
              • Dec 2023
              • 7
              That's what I tried to test when I bridged POWER_ON with DRV_ON. My thought that if there is voltage on DRV_ON then the backlight should come on.
              I tried that and it wasn't totally black as when it's off, it looked like there was something, but it wasn't a picture that would make sense - it was like just random colors in different pixels.
              I bridged it with the main board connected. Just shorted the two contacts with a wire briefly.
              • EazyBone
                • Jun 2023
                • 1337
                • United states
                No you have to test the LEDs without that circuit with a tester or something. That narrows it down. Then we know we need to look at it or not. Then we know it's PSU or MB.
                Try taking the DRV pin out of the harness from the MB but leave all the rest of the pins in place, then jump it so it's not potentially shorting on the MB (not sure if this is good advice but I do it and it works)
                Also, those lines on the screen.... Uhh, that's important lol what is going on there? How do you get that
                • KKinNJ
                  • Dec 2023
                  • 7
                  I'm not sure I follow.... How do I take a single pin out from the connector without damaging it?
                  I'm not sure what lines are you talking about...
                  • EazyBone
                    • Jun 2023
                    • 1337
                    • United states
                    Sorry *random colors on screen. Explain what's going on.
                    And take the connector out, you lift the tiny tab with some tweezers or something and it pops up, then you pull the wire out.
                    • KKinNJ
                      • Dec 2023
                      • 7
                      Thank you EazyBone and nomoresonys for your help with this. I got a new main board and the TV is fixed, so it was the main board after all. I suppose the random colors was also a symptom of that, but I can't be sure now, as I don't know what's supposed to be on the screen in such a failure mode.
                        • 12200
                        • U.S.
                        Yep, typical mainboard failure, glad you took the advice, thanks for followup.
                        • EazyBone
                          • Jun 2023
                          • 1337
                          • United states
                          awesome
                          • CrewmanRedShirt
                            Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                            by CrewmanRedShirt
                            Hello all,
                            As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                            07-13-2024, 11:02 AM
                          • htv239
                            LG UH8500 Backlight Troubleshooting Help
                            by htv239
                            I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                            Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                            What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                            10-11-2021, 01:53 PM
                          • Dogindelusion
                            Sony XR-77A80K 5 Red Blinks Troubleshooting
                            by Dogindelusion
                            Hi everyone! I am a new member and am new to electronics repair. I have a background in electrical engineering, but little experience in electronics.
                            I have a Sony XR-77A80K which will not turn on and has 5 blinking red lights in the stand-by light. I had previously done a forced factory reset, which removed the error code, and the TV regained functionality for a few weeks. I repeated the factory reset and again regained functionality. This happened a few times until I so I had to begin troubleshooting the error.
                            Observations:
                            1) I noticed I was not getting...
                            08-09-2023, 09:44 PM
                          • blues_spirit
                            practical courses for troubleshooting pc motherboards
                            by blues_spirit
                            Hello from France,
                            mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                            Do you think this is feasible for me? I...
                            12-18-2022, 12:56 PM
                          • Andre Gilbert
                            by Andre Gilbert
                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here๐Ÿค”?
                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting ๐Ÿ˜‚.
                            11-20-2024, 08:52 PM
