Samsung LN55C610 LCD washed out image, vertical bands
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung LN55C610 LCD washed out image, vertical bands
    The first three pics look great, what happened. Tab bonds? Try pushing.on.the two most outer tabs where they go into the panel.
    • whatusername
      • Dec 2013
      • 456
      i did and nothing changed i also added the carboard under the board like it said and on top to keep the frame off the chips but its still the same... the first 3 pics was the first 5 min of tv being on then it started acting up
      another thing i noticed... no t-con board? it goes from the main board to the panel where there is this long 20 inch skinny board connected to the panel
      • freakaftr8
        • Oct 2012
        • 3743
        Ah yes the new style all in one mmainboard. Cost cutting rears it's ugly head. Try freeze spray on the mainboard then try the long boards on top of the panel.
        • whatusername
          • Dec 2013
          • 456
          ok will do
          • unxetas
            • Dec 2013
            • 16
            yeah, that looks pretty different from mine Mine comes up with the bars and stays with the bars - they're also not random like yours, they're 6 equally spaced columns (actually, with the new t-con, there's really only 3 on the left).
            Since yours comes up normally and then starts failing, it seems like an overheating problem. Did you try the "tab bond repair" technique that involves adding thermal bonding material between the tabs and the frame? There are chips on the actual ribbons that can overheat, apparently..
            • Ancient1
              Strange LG TV issue : Image vertical lines in black screen
              by Ancient1
              Hi
              Asking for a friend.
              I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
              but here its the opposite !
              TV has new T-con = same issue
              A missing panel voltage would have global effect
              So , what should one do ? how can I find where the fault is ?
              Thanks !...
              02-05-2025, 03:37 PM
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
            • lowteq
              Partial Success Repairing Vertical White Bands on HP Z30i
              by lowteq
              Hello.
              I was given a HP Z30i LCD computer monitor that had several white wide vertical bands on it. I had another Z30i that was working and after a lot of swapping of components I found that the logic board, TCON board and associated ribbon cables were healthy. The problem was the ribbon cables that go from a long slender PCB across the top of the panel onto the panel itself. The problem connection was on the PCB side not the glass panel side. These ribbon cables are attached with some kind of heat set adhesive.
              I'm aware that this type of problem usually isn't repairable...
              03-27-2020, 10:49 AM
              HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
              09-06-2024, 10:56 AM
              HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
              This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
