Working through a problem with this TV. I really need some guidance.
The voltages from the power supply are good to the YSUS and ZSUS cards.
When both buffer boards on the YSUS are in place, the voltage drops out at the VSC and -Vy test points. both YSUS and ZSUS heat sinks remain cold.
If I remove the upper YSUS buffer board, heat sinks on both cards begin to warm up and the voltage to the 2 test points returns but I still have no signs of picture or backlight.
My question is...What would cause the voltage to drop out when the upper buffer is in place? I've already replaced the upper buffer and YSUS card and the symptoms remain the same. I've read in a few of the threads, that these buffer cards are not prone to failure.
Any help is appreciated
