lg 60pc45 Stanby Fault
  • tocold4u2
    • Dec 2012
    • 284
    • usa
    Re: lg 60pc45 Stanby Fault
    what powersuppky boards do u have ?
    • anotherdude
      • Feb 2013
      • 488
      • uk
      EAX31466401/9 EAY32961801
      the sub board
      EAY32961901 EAX31466601/8
      • tocold4u2
        • Dec 2012
        • 284
        • usa
        yea thats the same boards i have also..
          Do you have Vs from PSU, but no Va? What does Va do if you unplug the Y- and Z-sus? Note, if Va is short, there is a reasonable chance the plasma panel is bad, so keep that in mind.
          • anotherdude
            • Feb 2013
            • 488
            • uk
            VS is present and hits the right voltage, i've tried disconnecting all boards apart from the control board main board and power supplies and the VA never goes above 1v at power on
            am i correct to think that if i disconnect all ribbon cables from the panel to there boards and i still get no VA this would rule out a bad panel?
            • tocold4u2
              • Dec 2012
              • 284
              • usa
              #26
              did u check cp501 &cp601. its at top of sub power boarand at bottom of main powee board
                Va is only fed in through the Y- and Z-SUS, so if you unplug that power connector and Va does not rise it is probably not a shorted panel holding it down.
                • anotherdude
                  • Feb 2013
                  • 488
                  • uk
                  #28
                  right, good news I think, so the missing contact pad on that IC isn't important or?
                  any ideas on tracing the fault down?
                    It's a deliberate omission that pin. See above for tracing out Va fault by isolating Y and Z.
                    • anotherdude
                      • Feb 2013
                      • 488
                      • uk
                      #30
                      thanks tom, not much idea what i'm looking for tbh following the va pins from connector to connector they join onto 100v caps but thats as far as i can see at the moment will have another look later
                        Just unplug Vs/Va connector. Does Va rise or not?
                        • anotherdude
                          • Feb 2013
                          • 488
                          • uk
                          #32
                          just the same never goes above 1v
                            OK, there's a fault on the PSU. Is that fuse with the red band OK?
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Check all transistors and Mosfets located around the VA adjustable potentiometer. Especially the half moon looking transistors that feed off the leg of the adjustor.
                              • anotherdude
                                • Feb 2013
                                • 488
                                • uk
                                #35
                                seems to test fine, low resistance
                                • anotherdude
                                  • Feb 2013
                                  • 488
                                  • uk
                                  #36
                                  in or out of circuit?
                                    In circuit for now. Really need to find a schematic to suggest much. Diodes on output side can also be checked.
                                    • anotherdude
                                      • Feb 2013
                                      • 488
                                      • uk
                                      #38
                                      looked and looked for hours last night, the service manual doesn't offer much in terms of components
                                      guessing because it's such a old set, coming upto 6 years old
                                      • anotherdude
                                        • Feb 2013
                                        • 488
                                        • uk
                                        #39
                                        thanks for everyones input, giving up on this and hopefully a new power board will fix it, looking for a needle in a haystack IMO
                                        • tocold4u2
                                          • Dec 2012
                                          • 284
                                          • usa
                                          #40
                                          i hear ya there...im on my last nerve with my board also
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • cheeky2
                                            LG 42LG3000 Strange fault will not go into standby!
                                            by cheeky2
                                            I have this LG 42LG3000 Tv which operates on all inputs without any issues whatsoever. However when you try to turn the Tv off the screen goes blank as it would normally however it then turns itself back on again!
                                            So far I have replaced the main board without any resolution to the problem.
                                            When the inverters master and slave VIT71053.54 VIT71053.55 are disconnected from the power supply then the TV will turn off as it should (obviously without any ccfl output).
                                            I have read through a few posts for this model without anyone having this issue as far as I can tell.
                                            I...
                                            05-04-2021, 06:02 AM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                          • Crystaleyes
                                            Samsung BN44-00259A standby question
                                            by Crystaleyes
                                            Hi all.
                                            I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                            SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                            Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                            The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                            08-11-2023, 05:15 AM
