normande 32 -vestel
  • willyam1
    • Feb 2012
    • 112
    • israel
    normande 32 -vestel
    hi.
    tv come with problem thet its work ok and after 50-60 min shut down to stby.
    it was like the customer said.
    i open it and start to check trying to operert it but its giving flick to the backlight and then stby.
    p.s17PW26-4 V.1.
    ALL CAPI OK NO BULLGING .POLY CAPI 22N OK .
    3.3V STB 5VSTB.
    3.3V OK 5V OK.
    INSTED 24V 23.2V INSTED12V 11.4V.
    BIG CAPI 322-330V its seemsb that the pfc section works but low should be 370-400v .
    i check everthing diode opto pfc ic fan75259 no shorts vcc 15v steady no rippel to that ic.
    not shure if problem is in p.s but usely its the pfc problem.bl on ok anyone hade this problem in this power supply.
    willyam
    Re: normande 32 -vestel
    This PSU has a flyback output type PFC, so you don't expect 390V across the 22u/450V cap.
    1st try warming up PSU and see if it will shut down - use hairdryer etc.
    • willyam1
      • Feb 2012
      • 112
      • israel
      thanks tome i already try it no joy.its150uf/450v
      willyam
      • willyam1
        • Feb 2012
        • 112
        • israel
        dear tom.
        i found in electro tanya web thet one of the tech said to replace the 22n to 15n i did it and now tv works 24.5v 12.3v.
        i will put it to works and see the finel result.330v in big capi i dont understand what is the reason to it is 3 nf diffrent could help it i dont understand it from the diagram can you explain the reason?
        willyam
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
        • France_53
          Vestel tv, how to flip the image?
          by France_53
          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
          05-12-2024, 05:22 AM
        • FlailingEngineer
          Help with Bush Tv (Vestel 17mb95m Mainboard)
          by FlailingEngineer
          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
          05-31-2023, 06:52 AM
        • massimomax
          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
          by massimomax
          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
          spero che qualcuno può averlo per riprogrammare eprom. grazie
          Post in English !!!
          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
          02-28-2025, 07:27 AM
        • Adenitz
          Troubleshooting Vestel TV, has standby, but cannot turn ON
          by Adenitz
          I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
          Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
          Both boards are shown in the attached photos.
          What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
          12-27-2023, 03:43 AM
