samsung ps42c450b1w clicking
  • Manddave
    • Oct 2013
    • 58
    • Uk
    Hi there
    I have a samsung ps42c450b1w plasma tv
    It seems to have the clicking relay on the psu and will not turn on.
    The psu was changed but no luck.
    When the main ysus is unhooked the tv powers up but no pic
    When just the xsus is unhooked I get the same clicking on the power board and nothing.
    There are no bad caps visible.
    Can you help please
    Thx
  • Manddave
    • Oct 2013
    • 58
    • Uk
    Re: samsung ps42c450b1w clicking
    Anyone help plz
    • Manddave
      • Oct 2013
      • 58
      • Uk
      Anyone help with identifying which board is at fault as I have limited experience
      thanks
        Most likely Y-main -- can you post some pictures of it? Have you checked VS voltage?
        When replacing these boards it's sometimes needed and often a good idea to replace both X- and Y-main at same time, due to how they chain together, damage on one can damage the other.
        • Manddave
          • Oct 2013
          • 58
          • Uk
          Hi thanks for the reply
          I will have chance to look at this better tomorrow and get some pics
          I know it's not the power board for certain
          Can you tell me what voltage I need to check
            Vs is marked on the power board, it should be around 200V.
            • Manddave
              • Oct 2013
              • 58
              • Uk
              The vs on the power board to the ysus looks ok
              The vs on the ysus to the x is virtually nothing.
                Are you sure? They are directly connected to each other.
                • Manddave
                  • Oct 2013
                  • 58
                  • Uk
                  How do you mean?
                  The vs pin on the psu is showing voltage.
                  But the vs pin on the ysus that goes to the x board shows nothing
                    From what I remember there is a direct circuit trace between the Vs in and out on the Y-main.
                    • Manddave
                      • Oct 2013
                      • 58
                      • Uk
                      Ok my bad sorry I am getting voltage to the vs but losing it on and off with clicking psu
                      • Manddave
                        • Oct 2013
                        • 58
                        • Uk
                        Here are some pics
                        When ysus is unhooked the tv goes into its normal start up.
                        when its plugged in again i get 5 or 6 clicks from the psu and then nothing.
                        • capkid
                          • Oct 2010
                          • 1339
                          This may be one of those Samsungs in which you can test for shorts in the components on the heat sinks and quickly find your problem boards: https://www.badcaps.net/forum/showth...t=ns-50p650a11
                          LG Plasma Mal-Discharge Correction Service
                          • Manddave
                            • Oct 2013
                            • 58
                            • Uk
                            Changed out most of the boards on this tv and still the same
                            Anyone any ideas please
                            Would the buffers cause this problem?
                            • Manddave
                              • Oct 2013
                              • 58
                              • Uk
                              Any ideas what this could be please
                              • Ltank
                                • Jun 2013
                                • 776
                                So You removed the P.S. plug to Yand X board and it continued to cycle on/off? Remove the connector at P.S. from the main board. Does it still cycle on/off? If yes then its the P.S. No its the Logic board. according to the Tranining Module page 46
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Sounds like a logic board issue, arethee any leds lit up on the logic board when its power cycling? check tthe white rectangular ceramic fuse on the logic board to see if its open.
                                  • Manddave
                                    • Oct 2013
                                    • 58
                                    • Uk
                                    Led on logic board lights up when cycling. When main ysus is unhooked it starts up and displays nothing
                                    Also when logic board is unhooked from ps it goes through start up.
                                    If I unhook main board then it does nothing.
                                    Could I have been sold a bad psu?
                                    Can anyone tell me how to test psu
                                    Thx
                                    • Manddave
                                      • Oct 2013
                                      • 58
                                      • Uk
                                      completely disconnected the logic board from everything and the tv starts up with no picture
                                      when the logic board is connected to ps again it starts the cycling.
                                      Everytime it clicks the led on the logic board lights up. it does this a few times and shuts off.
                                      • Manddave
                                        • Oct 2013
                                        • 58
                                        • Uk
                                        Can anyone say if this is definitely the logic board. Due to it being replaced with a 2nd hand one
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
