Samsung Plasma HP-S5073 Sparkle
  • 2dbit
    • May 2012
    • 81
    I've got a bit of an issue with some random lit pixels across the panel on this 50" plasma. Here's some pics:
    I was hoping the random lit pixels across the screen were merely a power supply voltage issue. I was even delighted when I found all voltages under spec. I adjusted all to spec, but the problem still exists.
  • 2dbit
    • May 2012
    • 81
    Re: Samsung Plasma HP-S5073 Sparkle
    I am somewhat tentative about adjusting the timings on the set unless I know it is actually a timing issue. I do have a digital oscilloscope. It's of the 60Mhz variety, so quite a bit under what these boards operate at. I've read where people simply adjust the timings until the best picture is had. I would probably be less tentative if it weren't for that one band of pixels across the bottom of the screen. Makes me think there is something else going on here.
    • cadiman
      • Mar 2010
      • 397
      What boards did you replace?
      • 2dbit
        • May 2012
        • 81
        I haven't changed anything yet. So far, I've only adjusted all the power supply voltages to within 0.1v of panel specs.
        • 2dbit
          • May 2012
          • 81
          Does this seem like an issue on the buffer boards or more of a processing issue?
          • freakaftr8
            • Oct 2012
            • 3743
            I would say given the fact there's a white line across the bottom of the screen it might be more of a control board issue than anything else. You could try disconnecting the lower buffer board leaving the upper buffer board connected still and see if the sparkle disappears on the top side of the screen of course a bottom side going to be completely black that would be a good start. if the sparkles disappear replace lower buffer board.
              Can you post a close picture of the control board? At the very least, a malfunction in the main board can be eliminated.
              • 2dbit
                • May 2012
                • 81
                I took a pic of the Y-Main, I presume that's what you meant by control board? Here it is:
                If that's the wrong board, here's a pic of a few of them, let me know which one I should have taken a closer pic of...
                • 2dbit
                  • May 2012
                  • 81
                  As for disconnecting the lower buffer, I pulled the ribbons off, but to remove the board itself, I didn't want to damage the white connector between the lower and upper buffer boards, is it possible to remove the lower without also removing the upper? I'm not familiar with this connector and do not want to damage it...
                  • 2dbit
                    • May 2012
                    • 81
                    The white connector between lower and upper buffer boards, that's for daisy chaining the two correct? If so, would I be better off leaving the lower buffer connected to the main and the other buffer, but simply disconnecting the ribbons?
                      The control board is the one buried right under the main board.
                      • 2dbit
                        • May 2012
                        • 81
                        Sorry about that, here's a pic of the board you wanted in the first place!
                        • 2dbit
                          • May 2012
                          • 81
                          I didn't get the whole board in the picture, but more of the "business" end of it. If more is needed, I can zoom out a bit and get the whole board
                            That is the main board, the control board is under it.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Agreed. My previous suspicion of a buffer board is wrong. Those dots between the white lines are a dead give away . Looks like a control or mainboard issue. Try heating the main processor up on the control board.
                              • 2dbit
                                • May 2012
                                • 81
                                Sorry, this time hopefully I got the right board!!
                                • 2dbit
                                  • May 2012
                                  • 81
                                  I'll try and get an opportunity to hook the main board up enough to power the TV, then with it main board tilted out, I'll try heating that processor and see if there is any change in display. Unless there is something that you guys see on this board that suggests otherwise. (I do also have a 60Mhz digital oscilloscope, I realize it's well under the 200Mhz that would be ideal for TV work, but it should be enough to get a picture)
                                    Do you see the 2 x 2, 4 pin connector block labelled CN2008/2009? Middle left of board.
                                    Place a jumper across pins 3-4 (a jumper from a HDD option block works, as does bent wire.)
                                    Then unplug the rainbow coloured LVDS connector at the top of the board.
                                    When the TV is plugged in test patterns should appear, are these distorted or not?
                                    • 2dbit
                                      • May 2012
                                      • 81
                                      I think I went wrong somewhere. I did as you said, I installed a jumper across pins 3 and 4 of CN2009, and I unplugged the rainbow connector at the top of the board. I installed all the other cables to the Main board, and plugged it in. The fan turned on on the main board, the blue light on the front of the tv turned on, but it would not power on.
                                      • 2dbit
                                        • May 2012
                                        • 81
                                        In that pic, the one connector at the top is the only one disconnected. Not sure if that's what is preventing the power supply from coming up, or if it's the jumper.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
