42lg3000
  • charlierfc
    • Mar 2013
    • 93
    • scotland
    42lg3000
    Hi people,i acquired a 42lg3000 that has a temperamental fault,i was told that it sometimes come on no problem,sometimes wont fire up the backlight.i got the tv home,tried to turn it on,only got the flashing red led,then turned to blue but no backlight.i opened tv,done some quick tests found that the inverters wernt getting the 24v? done some probing on the main board for vlts when i turned tv on again,24v came to backligh-light on no problem,so i thought it must have been a bad cabled running from the main board,turned it off and on a few times,all seemed well.thought i was in luck,just a bad connection from the wire i fixed with the probe from the multi meter.put back back on tv,pressed on-red led flases till blue light but no backlight!doesnt seem to be sound connected via hdmi,opened tv up tv done some tests,no 24v to inverter?i unplugged one inverter,turned on ob no backlight but i caould hear the sound?
    plugged the inverter wires back in.tv came on with all working.off and on a few time tv would flash till blue light-no back light or sound.
    would a faulty inverter cause the tv to turn on but with no sound from the hdmi input?
    its a hit or a miss if it comes on,but when its on,it runs fine,no problems.
    where do i start?all caps look ok, any heads up to where to begin?
    thanks for reading
  • johnboy1313
    • Nov 2012
    • 1959
    Re: 42lg3000
    I'm really not trying to be a jerk. I swear. Your post is entirely too hard to read. Unfortuately, I can't help with your particular problem, but if you were to take a little time to add capital letters, and spaces where needed, I'm sure you would get more help.
    • charlierfc
      • Mar 2013
      • 93
      • scotland
      Re: 42lg3000
      forgot to mention,got a bit of a buzz from tv,so i turned the backlight down from 100 to 70,no longer get the buzz,well a small bit when tv first comes on as i think it starts with full backlight for a sec then ajusts to 70?
      • johnboy1313
        • Nov 2012
        • 1959
        Re: 42lg3000
        Does it sound like the buzz is coming from one of the boards or from inside the panel? If the panel, it could be a bad connection between the inverter and a bulb.
        • charlierfc
          • Mar 2013
          • 93
          • scotland
          Re: 42lg3000
          Sorry johnboy lol.I got lost typing away!I must try harder next time!
          • johnboy1313
            • Nov 2012
            • 1959
            Re: 42lg3000
            Like I said, I'm not trying to beat you up, it's just hard to read when the words are all jumbled together. Some folks might not even try to read it if they have to put too much effort into it.
            • charlierfc
              • Mar 2013
              • 93
              • scotland
              Re: 42lg3000
              Would that cause the loss of the 24v? Its quite hard to hear where it was coming from, i was thinking maybe a bad transformer on the inverter, or maybe the main board was not giving the signal to turn on the inverters? like i say, when its on it works great, its just hit or miss if it does!
              • charlierfc
                • Mar 2013
                • 93
                • scotland
                Re: 42lg3000
                I know, sorry i had the head down hammering away at the keyboard loi
                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                  by sam_sam_sam
                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                  I am comparing them to a brand new one that I installed
                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                  I going to let it run for several days before I remount back on the wall next to the...
                  09-05-2024, 06:48 PM
                • tennno`
                  RCA LED46C45RQ,Sound but no Back lights
                  by tennno`
                  Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
                  Has All voltages coming from main board.No voltage going to
                  Back lights from power board.Have no Schematic.Back lights work when
                  Led Back light Strip tester is used.Tester shows 110 volts from each
                  side.Also if you use the side controls and use the vol +or- tv shuts
                  down.
                  Thanks for any help
                  04-10-2022, 03:34 PM
                • dronerat
                  Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                  by dronerat
                  Hi Guys,
                  This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                  PSU: L48S6 FHS BN44-00807D
                  T-Con: BN95-01937A
                  Panel: CY-GJ048HGLVLH
                  MB: NA (Currently as the TV is assembled and forgot to take picture)
                  As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                  It was sent to an authorized service for repairs and returned with the...
                  05-15-2020, 08:03 AM
                • Christos Tsiligiannis
                  Marian Trace Alpha sound card repair help
                  by Christos Tsiligiannis
                  Hello to the forum.
                  My name is Christos, I am new to the forum here and i am posting from Greece.
                  So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                  To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                  So i tried asking for a schematic from the company and they would not give me one. Instead they...
                  11-18-2024, 05:26 AM
                  HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                  This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  09-12-2024, 02:30 PM
