sharp lc37bx5m
  • willyam1
    • Feb 2012
    • 112
    • israel
    sharp lc37bx5m
    hi to all.
    this tv come on green led light ther backlight for a few sec the go off.
    made the reset procedoor the letter K APEERS and the backlight goes off again.
    green led stay on .
    its seems to me that the inverter master slave is the problem or backlight ccfl is the problem IM3826-1 IM3826-2 RUNTKA216WJZZ.
    24v ok i check the inv transformer ok all fet ok.
    ic controller bd9777.
    how to bypass this protect inv problem.
    willyam
  • willyam1
    • Feb 2012
    • 112
    • israel
    Re: sharp lc37bx5m
    hi.
    to bypass the protect in ic BD9777 PIN 14 SHOULD BE CONECTED TO GND.
    backlight is working but after a few min one of the trasformer is very hot and can see the pulses very distortion.
    now have to find tran OR TO CHANGE THE INVERTER.
    WILLYAM
      Re: sharp lc37bx5m
      You could also have a bad bulb in the panel.
      • willyam1
        • Feb 2012
        • 112
        • israel
        Re: sharp lc37bx5m
        could be but useslly when bad bulb is bad the tras is not hot.
        willyam
