Samsung ps42a457 showing bad image
    First check
    Vs should be 205, it's at 150
    Va should be 54 it's at 41
    Unplug x main and y main
    All voltages are perfect out of psu
    If I plug either boards in, I get the above incorrect voltage
    Usually only 1 board has caused this
    Does it mean x and y main are both bad??
    Re: Samsung ps42a457 showing bad image
    No x and y connected
    Vs205 va54
    Just with x
    Vs154 va43
    Just with y
    Vs146 va41
    With x and y
    Vs140 va39
      Anybody??
        I would look into power supply area. Somethings wrong in the high voltage output section. It has no problem outputtinng the supply but once put under a load it looses its ability to keep up. Look to capacitors being the prob. Any swollen or bulged?
          Could be film cap on primary side going bad too.
            Agreed, I had a 42" AKAI plasma with a mylar film cap go bad.. Changed 6 of them.
            These are red or orange in color or green with 2 leads off the bottom.
