Panasonic 42 TV - tc-p42s30
  • mmoore5553
    • Oct 2013
    • 171
    I got an offer on this TV for 50 bucks. It comes on for alittle while and shuts off. Then he has to have it unplugged for awhile and then comes back on. I did not know if it was worth looking at. I have never repaired a TV so thought it would be fun project.
    What do you all think should i buy it ?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic 42 TV - tc-p42s30
    That's a tough one. Shuts off after how long? secs, minutes, hour?
    See if you can find out if the front led is blinking on shutdown and how manys blinks. it will be a seriies of blinks with a pause in between.
    there could also be no blinks.
    SJ have no SN boards, so these may have an issue with them.
    Have a look at this ebay listing and read the sellers comments regarding the symptoms and the quality of this panasonic. AFAIK he's a professional TV repairer and has access to genuine Panasonic parts.
    http://www.ebay.com.au/dsc/i.html?_f..._odkw=TNPA5349
    Unless you can do component level fault finding and work with SMD, this maybe a tough project.
    There seems to be a lot of issues with later Panasonics, maybe because they've gone SMD and removed a lot of the heatsinks, I don't know?
    • mmoore5553
      • Oct 2013
      • 171
      hmmmmm I guess i will stay away. I thought it might be a nice one to work on. I asked him on the led blinks earlier and he said he does not know. He just asked if i wanted it or not.
      • tw2005
        • Oct 2011
        • 6458
        Nice component level repair at best if you can handle it but if he's avoiding giving an answer he probably already knows it won't be an easy or cheap fix.
        No boards anywhere unless you want to cough up $200 or more and to get a TV even a panasonic repairer reckons is poor reliability.
        Good for the experienced trouble shooter who likes a challenge and prepared to lose $ on it if it goes all bad.
        First thing i do is look up the model on SJ and if you see a particular board out of stock, keep searching that board and when you find none, good chance the main failure point is that board.
        Sorry to ruin the party, but you know at least what you may be taking on.
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • Biruslapio
          Panasonic P58V11B 8 and 12 blinks error "fix"
          by Biruslapio
          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
          04-13-2021, 07:13 AM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
        • CrewmanRedShirt
          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
          by CrewmanRedShirt
          Hello all,
          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
          07-13-2024, 11:02 AM
