Magnavox 42MF231D/37 will not completely power off, dim "backlight"
  • Robb
    • Sep 2013
    • 159
    First off, thanks to the badcaps.net community, I would be lost and bored without you.
    I just fixed a Y-buffer on this set. Everything seems normal except when I turn it off - by remote or tv's power button - it still has a very dim "backlight". I've read the service manual and searched around this forum and the web but haven't found this particular problem. Of coarse unplugging it solves the problem but I'm hoping for a more convenient solution. Anyone ever seen this issue before or know what might be causing this type of behavior?
    Re: Magnavox 42MF231D/37 will not completely power off, dim "backlight"
    Does this model have a digital TV tuner? Does it work properly? (DTV tuner can sometimes cause this issue.)
    • freakaftr8
      • Oct 2012
      • 3743
      Yes this tv does. Worked on many of these sets and for some reason this happens to some. Its a firmware issue. Update if possible thru usb.
      • Robb
        • Sep 2013
        • 159
        According to the service manual it has NTSC & ATSC. Digital STB is an option in the menu & under OSD Operation in the SM it says:
        Channel turning
        Available channels:
        - Cable (analog NTSC or digital QAM)
        - Terrestrial (analog NTSC or digital ATSC)
        I don't really know. It accepts a signal from the cable box
        • Robb
          • Sep 2013
          • 159
          Thanks freakaftr8 for confirming and tom66 for bringing it up. In the menu/settings I set all the inputs -except the HDMI- to "NONE" and it turned off after about 10 minutes of standby mode.
          I downloaded 42mf231d_37_fus_eng.zip firmware and extracted it to a Fat32 usb drive using Linux but the TV didn't find the file in automatic update mode (turn TV on w/usb inserted) or in manual mode via the menu/settings. The Read Me says the usb format should be FAT/DOS so I think I just need to find another usb drive that doesn't have 10 LiveOSs on it as I'm too lazy to reinstall them.
          Edit: 3.5 hours later it turned itself back on
          • Robb
            • Sep 2013
            • 159
            After discovering there is no option on Linux with GPartEd or TestDisk to format partitions to FAT (only FAT12, FAT16, FAT32) I fired up a Windows box > opened Command Prompt > typed format e: /fs:FAT > copied Autorun.upg (downloaded from http://www.m4c.magnavox.com/cgi-bin/...scy=US&slg=ENG) to the USB drive> tried to install the firmware update and still it wouldn't find the update on the USB drive...not sure what I did wrong.
            On a positive note, the TV only turned itself back on only once (mentioned in the edit above) and regularly powers off completely whether using the remote or the onboard power button.
            Though perplexed I am happy it has no issues now. Thanks & Cheers
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • BoardHoarder
              XBR-65X850D Backlight/Power On Help
              by BoardHoarder
              Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
              02-09-2024, 11:00 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • hikomalek
              TV LG39LN575S, no backlight power, EAX64905301(2.2), MAP3202
              by hikomalek
              I would be really grateful for your suggestion how to repair a no backlight power on TV LG39LN575S. There is a visible menu on a screen when I use external torch (so logic board and panel works correctly), there is just no backlight.
              I have connected a logic board which is turning on power board and disconnected LED backlight cable.
              Power board:
              REV2.0 2013.03.28
              PCB: EAX64905301(2.2)
              LGIT PCB P/N: 3PCR00184A
              IC LED driver MAP3202
              MAP3202 voltages:
              (1) EN = 2.75V
              (2) VCC = 12.05V
              (3) GATE = 0 V...
              07-25-2024, 10:30 AM
