me vs plasma well plasma is winning ok I have a vp50 hdtv20a.... What ive replaced Several caps, sck 206, 1 fet all circled in pic below ok issue now relay not engaging (now I know I shouldn't have but when I manually engage relay tv works but if I do not manually engage tv does not turn on and green light blinks once for VA UVP still very new at this so any guidance would be greatly appreciated..
vizio plasma
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by jm1234Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but... -
by jimbofzHi ,this appears to have 2 faults
black lines on raster and faulty main board ?
let me explain futher
at switch on the relay does a few slow clicks with red led blinking and repeats every 10 seconds .i ran the psu into 2x 100w lamps and it runs fine all day supplies good .
i removed y sus and x sus checked for dry joints and checked all igbt anf fets all ok
next i removed buffer and checked for any s/c buffer ics all ok
so i unplugged feed to main board from logic board and linked test points pin 3 and 4 ,
tv still trips but now i get plain... - Loading...
